This 45x45x45 mm cube houses several powerful sensors in order to track motions ore gestures as well as the environment. A pouch battery provides power, an IMU tracks motion, two cameras with a ToF sensor can create a 3D modell of surroundings and a touchscreen provides direct user in- and output. All signals are processeed by a microcontroller and sent via bluetooth to another device.
This is the follow-up project to a motion remote prototype (https://hackaday.io/project/167738-motion-remote) in which motion sensing broadcasted via bluetooth to an Android device has been demonstrated.
In order to test functionality of electronics while avoiding cost risks due to small form factor a development board has been designed. Gerber files and component lists are attached.
