Test without battery protection board
A project log for Black & Decker - Dust Buster: battery replacement
Revive a B&D Dust Buster by replacing the NiCd/NiMH battery with 18650 cells
benjaminaignerbenjaminaigner 09/29/2019 at 14:490 Comments
For testing purposes, I've tried the vacuum without a battery protection circuit.
The performance was good, but not the best. The battery capacity seems to be enough for ~10-15min, but the cheap "9900mAh" batteries are getting warm after ~30s.
The next try will be with 2x2 batteries (1+1||1+1), so this is the added 2nd battery holder:
I will measure the runtime with 4x2Ah cheap cells and 4x3Ah good cells.
