ARX MK0
This is the main variant of the ARX Hand Project which focuses on a bringing a fairly advanced low cost robotics hand design. This design is quite advanced and can be quite a challenge to build and use, as it involves close integration of motors and electronics to allow for function.
ARX MK0 Variants
Design Intentions
Many advanced myo electric prosthetic devices available in the market cost well over thousands of dollars which can be difficult for people to afford. ARX Hand Project hopes to create a highly affordable and easily producible motorised hand design with the help of modern low cost FDM printing and circuit fabrication facilities.
Design Aims
Design Summary
The design brings 5 degrees of actuation using motors along with 11 degrees of freedom in joints. It uses 4 micro geared motors which are controlled using a custom PCB and Arduino. Hand parts can be printed using any printer capable of printing PLA, and can be printed with or without supports. Additional materials required are some self tapping screws, 3mm nylon filament, elastic cord and 0.5mm to 0.8mm diameter braided fishing line.
Hand Design
3D Printing
The ARX Hand Project can be printed using any standard FDM printer that can print PLA. Majority of prototypes I have printed are in PLA using a fairly modified RepRapPro Huxley 3D printer purchased in 2014. The design has been based around 0.2mm layer height with a 0.4mm nozzle, so using different parameters may affect part fit. Some additional small geometries have been added to the models to compensate for some effects caused by 3D printing.
Typical print specifications:
Print materials:
Disclaimer
Although I have some experience in designing things from being self taught, I do not have any degree or qualification. These designs should therefore not be used as a medical device or to be used in any situations where it may cause injury or harm. I can not be liable to any injuries, harm, or issues resulting from the use of the design and therefore should only be used at your own discretion.
License
This work is licensed under a Creative Commons Attribution-NonCommercial-ShareAlike 4.0 International License.
