Low battery detector misfires
A project log for IR Activated IrDVR
Raspberry Pi based, portable security ir camera with IR motion detector
visualkevvisualkev 08/06/2014 at 05:100 Comments
I think the low battery detector misfires when the camera and the flashlight turn on causing the power supply to dip, but it doesn't happen every time. My multi-meter isn't fast enough to register such a short blip. I need to figure out a fix based on that hypothesis, probably a capacitor across the power supply to  flatten out the dip a bit
