New Chassis for project
A project log for IR Activated IrDVR
Raspberry Pi based, portable security ir camera with IR motion detector
visualkevvisualkev 08/24/2014 at 20:090 Comments
I was a bit too optimistic about fitting the project in the case I first tried. This old hard drive harddrive carrier  is significantly larger, and is metal, originally on 5 sides. I will need to fashion the top side piece and optical window side piece myself.
