Pixel Badge 2 : Dark Pixel
A WS2812S conference badge
Pixel Badge 2 : Dark Pixel is an electronic conference badge based around the WS2812S LED.
This badge is a continuation on a theme I started last year with my 'Shitty PIxel' SAO that eventually morphed into something I thought qualified as a full-on badge. I don't think I saw my original idea play out the way I had envisioned so I'm continuing to develop something electronic and interesting based on this design.
Design
The look of the badge is modeled after  the WS2812 series of LEDs by WorldSemi. The shape the copper pads form caught my eye while working on a large neopixel installation a few years back and I thought it would look good on a t-shirt. This came back to me when I started learning about PCB art and I couldn't resist the meta idea of using WS2812's on a giant WS2812. This is one of the key points I missed with the SAO I did last year. I'm making sure to use the appropriate LEDs this year. A large part of the aesthetics this year are the addition of bent brass tubes to emulate the bond wires in the LED. These were inspired by Mohit Bhoite's incredible freeform electronic sculptures.
Features
The feature set isn't fully fleshed out yet, but here's the wishlist so far:
  • User controlled animation sequencer.
  • Choose between internally generated neopixel data or take external source.
  • Output neopixel data (think daisy-chaining badges together)
  • Brass tube "bond-wires" cap-touch inputs.
  • Lipo rechargeable battery.
  • USB Serial interactivity.
*SECOND WAVE Of FEATURE IDEAS*
  • Wireless Bluetooth badge to badge color infections
  • Battery monitoring mode, led displays red/yellow/green based on battery life
Hardware
Right now, I'm prototyping using a Hornbill ESP32 dev board and I've essentially copied all of the components from the devboard to the badge design. So the main bits are:
  • ESP32 WROOM
  • CP2102 for USB/UART
  • AP2112 Voltage Regulator
  • MCP73831 LIPO Charge
I'm unsure if I'll be making any major hardware change until the features are solidified.
Software
I've only used the Arduino IDE in the past, and this is what I'm sticking with at the moment. From what I understand if I want to use the WiFi/bluetooth capabilities of the ESP32, I may need to switch to native C. We'll cross that bridge when we get to it.
  • Assembling and Testing v2.2 PCBs
    blinkingthing10/11/2019 at 23:29 0 comments
    Assembly Plan / Prep
    While waiting on the components to arrive from overseas, I made a cheatsheet for assembling my board. I saw someone else do this for use when assembling diy ANDnXOR DC24 Bender badge's and found it to be helpful.
    Received Parts
    Most of the components came from LCSC but some that weren't available there came from Digikey. I've had the brass tube in stock for a while but I ordered that through Amazon a few months back when I started experimenting with it.
    Actual Assembly
    The assembly for these badges was inspired by watching dr_n0pesl3d's twitch streams where they used a hot air rework tool to solder components one at a time. I had never seen this before and didn't recognize it as a possibility. I thought you only re-worked previously soldered components, or used an oven the reflow everything on the board at once. This concept of using the hot-air tool to assemble boards one component at a time wasn't a concept that existed in my head previously. Placing the solder paste with the syringe for each individual component is probably my least favorite part of this process as I'm inaccurate and wasteful.
    Assembled and flashed before bond wire installation
    Moment of Truth - Plugging in USB.
    After I got all the components on the first board I wasn't really sure how to go about testing it before plugging it in and taking it for a spin. I ended up visually inspecting all IC's and the USB connector for any bridges/shorts. After cleaning those up I used the breakout pins and a multimeter to test neighboring pins on the EPS32 to double check for bridges/shorts. Once I was semi-confident that nothing was going to be destroyed when I applied power, I plugged it in.
    I could not believe that it didn't go up in a puff of smoke as soon as it was plugged in.
    What Works What Doesn't
    I had a bit of troubleshooting to do as nothing really happened when I plugged in my board aside from the power indicator LED lighting up (which was still sort of cool cause I've never powered anything through USB before). It turned out both the CP2102 and ESP32 hadn't completely/correctly reflowed. I ended up having to hand solder all 5 of the v2.2 badges I made because I couldn't get them to completely reflow correctly using the hot air tool I have. I assume I'm not heating up both the pixel badge board and the ESP32 WROOM board in close enough synchronicity to correctly reflow it. I've gotten a handle on the CP2102's QFN package now, but it was the most difficult chip I've soldered in my electronics career thus far.
    Indescribable Feeling of Uploading something directly through a USB Port
    After I got the ESP32 and CP2102 installed correctly, I plugged in the badge via USB and checked out the list of USB devices on my computer. Seeing the a UART chip by Silicon Labs listed in my list of USB devices gave me a rush of excitement that I don't feel often. I know it's probably trivial to most people more heavily involved with the hardware world, but this felt like unlocking a door that l've been stuck behind for a while. It make's me feel like I might be capable of designing and manufacturing actual electronics.
    Notice the R G B indicator lights and green bodge wire.
    Battery Hissing
    One of the major components to check was the LiPo battery charging circuit. When a LiPo is plugged in and charging, there is an extremely quiet and high pitched whining/screeching/hissing sound that emanates from the board. I can't tell if it's the actual battery or some of the components on the board making the noise. This is the scariest part of the build for me because I copied the schematic, don't understand it electrically, and now have a potential problem to figure out. I double checked the schematic and components and I don't think I did anything wrong. I let the battery charge (outside) for 3/4 hours and it never exploded or caught on fire, nor did the battery start...
  • Notes on the Brass Tube "Bond Wires"
    blinkingthing10/06/2019 at 19:55 0 comments
    Credit Where Credit is Due
    A few months back, maybe even a year ago, I remember seeing these beautiful, delicate, impossible looking electronics projects based around thin brass tubing by Mohit Bhoite. Across his different social media platforms I gathered enough info to try getting creative with the brass rods myself. Please go check out his work, it's very interesting.
    What I Used
    Instructions, calipers, pliers, flush cutters, and 1/16" K&S brass tube
    My first attempt at manipulating the brass tube used these tools.
    Measuring in KiCad
    I used measurements that I had previously made in KiCad to start figuring out how long the brass tubes needed to be for each individual 'bond-wire'. I did this with KiCad's Measurement tool, placing the measurements on the user drawing layer. I then printed out the sheet you see above.
    Measurements made in KiCad
     Through trial and error I found that I was adding between 6 and 7mm to the distance between the holes on the PCB to get a length of wire with two 90º-ish bends that would be raised up just a little bit above the surface of the PCB.
    After I figured out how long each of the ten individual (and unique) tubes needed to be, I made a list of lengths, measured and scored each length with the caliper, cut them with my flush cutters, and bent them with the needle nose pliers. I did my best to keep the two bends on the same plane and tweaked them into position as needed. I attempted to use the K&S tubing bender, but it's designed for larger diameter rod/tube and it didn't work any better than my hand and the pliers in my opinion.
    Pre-bent bond-wire
    Using the flush cutters flattened out the tube where I cut it, so I used the pliers to force the tube back into a tube-like-shape that would place nicely with the round holes they were meant to mate with. I'm being pretty lenient with the tolerances here so I was able to bend any tubes that didn't land perfectly in their holes until everything seated nicely. I also didn't care too much about marring the ends of the brass tubes as they would be nested within the hole in the PCB and I didn't think you'd be able to see many of the imperfections.
    Fairly clean fit/finish
    I can get a really nice fit my bending the brass into the exact position I want it, and it snuggly fits into the 1.7mm holes in the PCB. The tension of the bent metal was enough to hold the tubes in place while I flipped over the board and soldered them into place. For the most part they all soldered very nicely save for one tube (H10) that was protruding a little bit. I will be mindful of this in the future.
    Overall, the front of the PCB looks extremely clean as far as the attachment of the brass tube, especially in comparison to the first version of this board where I essentially welded the tubes to the large copper pads.
    H10 wasn't cut as short or as clean as the rest of the brass tubes
    Here's a short clip of me the first bit of code I have running on the first prototype. It's a slight modification to the Adafruit Neopixel strandtest example that allows for touch input.
  • Continuation of a Theme
    blinkingthing10/06/2019 at 17:46 0 comments
    Clockwise from top left. Protoboard, Cardboard v1 and v2, followed by v2.2 and v2.1 of Pixel Badge 2 : Dark Pixel
    I wasn't finished with this whole pixel pcb idea after Defcon 27 so I'm continuing to develop it.
    A huge chunk of inspiration for part of this project came from Mohit Bhoite's brass rod electronic sculptures. This is where I began my prototyping. I ordered some brass tube from K&S metals per Mohit's suggestion and attempted to test it's solder-ability and continuity on a protoboard.
    Cardboard
    After I confirmed that the basic idea would work, I made my first cardboard badge prototype. I was in the middle of reading Adam Savage's "Every Tools a Hammer" and it may have inspired me to work with cardboard before jumping directly into KiCad and ordering PCBs.
    I started with an SVG of the shitty pixel SAO I made last year, just blown up in size to around 100mm square. I quickly started to come up with a list of changes I wanted to make to the overall design as well as the size.
    After the first cardboard badge, I started to work in KiCad and made a rough design and printed it out 1:1, and pasted it to another piece of cardboard for a second test. This 2nd prototype was used for testing the lengths of brass rod I would need for the bond-wires.
    FR-4
    I moved on to ordering a PCB prototype after being satisfied with the size of the board and feasibility of including brass tubing. Something new to me on this board was getting custom size holes drilled that would accept the brass tube. The brass tube is 1.5mm in diameter so I used 1.7mm holes in hopes of having enough clearance for an easy but solid fit. I completely screwed this up in KiCad by making the pad on the hole's footprint 1.7mm wide, but the hole that was to be drilled got left at it's default setting. Lesson learned ;)
    With the holes not being wide enough to accept the brass pipe, I ended up soldering directly to the face of the PCB with copious amounts of solder. In addition to looking terrible, this reduced the number of unique touch inputs I could play with because some of the brass rods were now sharing an electrical connection via the larger copper pads on the front of the PCB. This was disappointing but I was still able to test some ideas and make some progress so I suppose it was still a success.
    V2.2
    I'm now on the 2nd version of the dark pixel board and this time I got the hole drill sizes correct. I've also migrated all the circuitry from the hornbill dev board onto my badge in hopes that I will be able to utilize the lipo charger and USB to UART. I've yet to receive all the components so I haven't been able to fire one up.
    That's all for now, the next update will come in about 2 weeks when I get  the rest of the parts for v2.2.
View all 3 project logs
deelstra wrote 10/10/2019 at 18:20 point
The K&S cutter does not have guide rollers, and instead uses molded plastic blocks.  This can cause thin tubing to deform rather than rotate.  An example of an inexpensive cutter is here: https://www.amazon.com/ABN-Mini-Tube-Cutter-3mm-22mm/dp/B01M66AFTY/ref=zg_bs_1232270011_56?_encoding=UTF8&psc=1&refRID=EE4XZ8FJRP489E9MY6J9  this is NOT an endorsement, just an example of a usable tool.
blinkingthing wrote 10/11/2019 at 02:30 point
Wow! Thanks for the advice. I will give this a shot
deelstra wrote 10/10/2019 at 17:30 point
Have you tried using a tubing cutter?  There are small versions used for brake and fuel lines, obtainable at any auto parts or plumbing parts vendor. These keep the tubing round while making a clean cut, requiring minimal finishing.
blinkingthing wrote 10/10/2019 at 18:05 point
I did try using the k&s tubing cutter on a previous project but found it a little clumsy and slow. But I honestly may have been misusing it. Plus I’m impatient. I’ll need to re-visit it, it could save me time finishing the squished ends.
Neon22 wrote 10/09/2019 at 23:29 point
Put (fine) sand in the tubes before you bend them. They will  not collapse.
blinkingthing wrote 10/09/2019 at 23:46 point
I will try this! Thanks!!
Mike Szczys wrote 10/07/2019 at 22:22 point
Those "bonding wires" look fantastic!
blinkingthing wrote 10/09/2019 at 23:50 point
Thanks! Mohit Bhoite’s work was a huge inspiration. Looking forward to his Supercon talk.
Mike Szczys wrote 10/10/2019 at 00:09 point
Yeah! I met him at KiCON and he had an amazing handheld game of snake with an LED matrix that was free-form wired in his awesome style. He even had a beutifully-built case for it so he could travel with it and avoid it getting destroyed.
Definitely going to be an amazing talk!
