DIY SCADA / cat feeder
A mostly 3D printed automated cat feeder (part of my SCADA)
This build is based on the great design of Thomas Krichbaumer (thingiverse.com/thing:3623148)
I made some changes to the bowl support (to use a glass bowl), the case and the lid.
Its an automated cat feeder for dry food. The load cell (HX711) below the bowl constantly reports how much food is left. When its feeding time the build in arduino gets a trigger signal from my smarthome (via ModbusTCP) and the bowl gets refilled if needed. The dosing process itself is controlled by the Arduino.
The auger is driven by a Nema23 stepper motor which is controlled by a TMC2208 driver.
Please see also my smarthome SCADA project: https://hackaday.io/project/14862-diy-scada-smart-home
The final test run:
Button, status LED, Data connection and supply voltage:
A bit messy but it fits...
The supply for the glass bowl.
Graphics Interchange Format - 15.62 MB - 10/01/2019 at 05:54
Preview
Download
  • 1 × Arduino Mega 2650
  • 1 × Arduino Ethernet Shield
  • 1 × Nema 23 Stepper
  • 1 × TMC2208 Stepper Motor Driver
  • 1 × 230VAC to 12VDC power supply
View all 9 components
View all 3 project logs
Clay Graham wrote 12/25/2019 at 14:49 point
Wow. Super impressed by this project.
Dan Maloney wrote 10/01/2019 at 15:03 point
Been meaning to build one of these for our cat, who likes to wake me up at 4:00 AM to remind me that he hasn't eaten EVER and needs to be fed right away. But then I realized that I could use something similar for my chickens. Might have to think about ways to build a larger, weatherproof version.
stefan.schnitzer wrote 10/02/2019 at 06:26 point
That's why my feeding timer is set to 4:01 AM.
Mike Szczys wrote 10/07/2019 at 22:20 point
We've built a cozy home for our cats in the basement and close off the cat door after about 10:30 at night. They'd also like to wake up the house at 4am.
Nice work on the printed auger, that's always the part that stopped me on a multi-dose feed, all I've ever managed are 1-shot feeders.
