Close to Finished.
A project log for Aqua328 flexible aquarium controller
A flexible and adaptable controller for Aquariums or other stuff based on the ATMega328P
owenOwen 06/23/2020 at 20:060 Comments
I now have a lid switch fitted to the aquarium (a waterproofed reedswitch triggered by a magnet in the lid flap)
And I have done a load of work using the time loops I implemented in v2.0 to add reminders for Feeding, simple beeps and a message after 24 hrs, more aggressive beeps and message after 48 hrs. Opening the lid clears the message.
The lid plays a tune when opened and beeps periodically as a reminder until closed.
When the lid is open pressing the button triggers a maintenance mode which fades the light rapidly off and disables the fan until the lid is closed,
Finally; long pressing and holding the button when the lights are On rapidly decreases the on timer to allow a shorter off period to be set if power was turned off during maintenance.
I'll test this on my proto-board and then on the actual tank. If all is good I'll release v2.1 and mark this complete for now.
