Memory module
A project log for Super Micro Relay Computer
Going back almost 200 years, to what could have been the very early beginning of electronic computing!
stefanoStefano 12/08/2020 at 21:4411 Comments
As mentioned the memory is one of the two remaining parts of the computer to be built (the other one being the mostly mechanical punched tape reader).
For this I've tried to see if a ready design was available, but until now I didn't find anything suitable. Many relays computer implementations I've seen are attached to modern static RAM with some adaptor. The others are using diodes, as the TIM8 one, but I'm trying to avoid them in the construction since they were not available in the middle of 1800.
The solution I'm thinking to implement is using just relays and capacitors. Not sure if it is the simplest as I'm always trying to push for, and I'm posting it here also to see if someone can improve it or suggest a new design.
To write first erase content with EnableRead without Read signal, then switch off EnableRead and switch on EnableWrite and put on the bus what to write.
To read switch on the Read signal than EnableRead will load the Memory read register with the value that is being put on the bus. Release the Read signal when the value is not anymore needed on the bus.
Notes:
1. The data is stored on capacitors, the relays form just the "memory controller" part
2. Reading content "refresh" also the capacitors memory
3. One of the addresses (zero in the example picture) is filled with switches instead of capacitors in order to save one control line and two relays that else should be dedicated to input read
Relays count for 8 bytes (64 bits) memory:
+ 14 relays for address decoding (2+4+8)
+ 2 for EnableRead
+ 2 for EnableWrite
+ 8 for the Memory read register (can be dpdt)
= 18 4pdt + 8 dpdt relays (plus 56 capacitors and 8 switches to complete the circuit!)
alice crush wrote 12/25/2020 at 07:14 point
another idea occured to me... why not have two muxes... you can support more memory that way.  place the second mux on the ground side of the caps.  Imagine if your current circuit were only the 0 plane of a 2d grid of caps... just a thought...
Stefano wrote 12/25/2020 at 14:50 point
Didn't get how the circuit should look  like.
I did an intermediate design joining all bit at the same address on the negative side and all the bit of the same "2's power" on the positive side and putting relays on both sides (positive and negative), but this was creating loops and so I had to change it.
alice crush wrote 12/27/2020 at 19:18 point
maybe you've already tried this but instead of connecting all the caps in on big common connection to ground... multiplex their connections to ground that way you get 2x the address bits to the array of caps... just an idea...
Stefano wrote 12/28/2020 at 10:57 point
As reported I tried one design connecting separately all bits of each address to the ground (and selecting with relay the one that should connected each time), but this design do not work. The reason is because then you should connect more than one together on the positive side (the one that are disconnected on the negative side, and in my case was for example bit0 of all the addresses together, bit1 of all the addresses together, etc.), and this configuration is forming loops. As in a keyboard matrix you could avoid them with diodes, but I don't want to use them.
If you think you've some ideas try to write the schema or even prototype it, I'm more than happy to adopt each relay saver circuit if they would work!
alice crush wrote 12/22/2020 at 23:40 point
a buffer latch is a good idea! doesn't have to be the R register.  hack on!
Stefano wrote 12/25/2020 at 14:44 point
It was to try to save relays! ... I'm an optimizer type! :)
alice crush wrote 12/22/2020 at 23:35 point
where is the refresh circuit?  will the caps last long enough... prototype! id love for this to work, but i'd feel beter with a prototype or test version... good luck !  hack on!
Stefano wrote 12/25/2020 at 13:25 point
For how it's designed reading values immediately also refresh charge. So if needed each some time a memory read cycle can be done.
I prototyped an earlier version and worked. The capacitors were still able to be red  after half hour without refresh.
Note: the capacitors I have (in abundance) are 100uF; they are enough for the DPDT small relays, but not for the 4PDT ones (1mF seems to be good for them); this anyway do not affect the relays counting since DPDT should be used just on buffer latch and for this just 2 contacts were used
alice crush wrote 12/27/2020 at 19:27 point
I don't see how a read refreshes the caps read... but 1/2 hour retention time wow!  maybe it's better if you just build it, and i'll keep my ideas to myself
Stefano wrote 12/29/2020 at 11:21 point
If you look at the circuit, with EnableRead "on", the Read signal goes also to the positive side of the capacitor and charge it if the bit is 1 (or to discharge through the coil of the memory read register if the Read signal is disconnected, useful to clear memory).
Your doubts maybe doubts of others and your ideas might be good but will be surely unuseful anyway if not expressed! Not much discussions on this "niche" projects so please go on! ;)
Stefano wrote 12/21/2020 at 23:58 point
One idea I was pondering is reusing the R register also as the memory read register... This could be done, but then the memory could not be used in operations with Q since the result register is acting also as input! So no way unfortunately, since this is a must for proper programs.
