Firmware
A project log for Flounder Keyboard
A low-profile mechanical keyboard
deʃhipudeʃhipu 12/02/2019 at 23:230 Comments
In its simplest form, keyboard firmware is not rocket science. You basically need to do three things: scan the key matrix to see which keys are pressed, translate the matrix locations into key codes and modifiers, and send USB HID reports with lists of currently pressed keys. Easy.
So why is the KMK firmware so large? Well, it's written using an "enterprise" approach — everything is a class that has a hierarchy at least four levels deep, with abstract interfaces, pre- and post-event hooks, handlers, validators, layers of abstraction, flexibility and extensibility. Also RGB LEDs and Unicode emoji. Unfortunately, removing all the things I didn't need would require quite a bit of work, as despite having so many layers of abstraction, the code is actually pretty tangled. So instead I decided to just write the most naive code I could, and see if that works. I came up with this:
import board
import digitalio
import usb_hid
COLS = (board._C1, board._C2, board._C3, board._C4, board._C5, board._C6,
    board._C7, board._C8, board._C9, board._C10, board._C11, board._C12,
    board._C14, board._C13, board._C15)
ROWS = (board._R1, board._R2, board._R3, board._R4, board._R5)
def run(cols, rows, matrix):
    report = bytearray(8)
    report_mod_keys = memoryview(report)[0:1]
    report_no_mod_keys = memoryview(report)[2:]
    for device in usb_hid.devices:
        if device.usage == 0x06 and device.usage_page == 0x01:
            break
    else:
        raise RuntimeError("no HID keyboard device")
    cols = [digitalio.DigitalInOut(pin) for pin in cols]
    rows = [digitalio.DigitalInOut(pin) for pin in rows]
    for col in cols:
        col.switch_to_output(value=0)
    for row in rows:
        row.switch_to_input(pull=digitalio.Pull.DOWN)
    last_state = bytearray(len(cols))
    layer = 0
    while True:
        changed = False
        for x, col in enumerate(cols):
            col.value = 1
            bits = 0
            for y, row in enumerate(rows):
                bit = row.value << y
                bits |= bit
                if row.value != bool(last_state[x] & (1 << y)):
                    changed = True
                    code = matrix[layer][y][x]
                    if code == 0:
                        pass
                    elif code == 135:
                        layer = int(row.value)
                    elif code > 127:
                        modifier = 1 << (code - 128)
                        if row.value:
                            report_mod_keys[0] |= modifier
                        else:
                            report_mod_keys[0] &= ~modifier
                    else:
                        if row.value:
                            for i, value in enumerate(report_no_mod_keys):
                                if value == 0x00:
                                    report_no_mod_keys[i] = code
                                    break
                        else:
                                if value in (matrix[0][y][x], matrix[1][y][x]):
                                    report_no_mod_keys[i] = 0x00
            col.value = 0
            last_state[x] = bits
        if changed:
            device.send_report(report)
Of course you need a main.py file to run this:
import flounder
MATRIX = (
 (b'\x1e\x1f !"#$%&\'-.\x00*I',
  b'+\x14\x1a\x08\x15\x17\x1c\x18\x0c\x12\x13/01L',
  b'5\x04\x16\x07\t\n\x0b\r\x0e\x0f34\x00(K',
  b')\x81\x1d\x1b\x06\x19\x05\x11\x10678\x85RN',
  b'\x809\x83\x82\x00,\x00\x00\x00\x86\x87\x84PQO'),
 (b':;<=>?@ABCDE\x00\x00\x00',
  b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00',
  b'\x81\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x85K\x00',
  b'\x80\x00\x83\x82\x00\x00\x00\x00\x00\x86\x87\x84JNM')
flounder.run(flounder.COLS, flounder.ROWS, MATRIX)
Yes, it's not very human-readable. The MATRIX actually defines the codes of all the keys in two layers. Of course I didn't write it like that. I generated it with this code:
from micropython import const
import pprint
_A = const(4)
_B = const(5)
_C = const(6)
_D = const(7)
_E = const(8)
_F = const(9)
_G = const(10)
_H = const(11)
_I = const(12)
_J = const(13)
_K = const(14)
_L = const(15)
_M = const(16)
_N = const(17)
_O = const(18)
_P = const(19)
_Q = const(20)
_R = const(21)
_S = const(22)
_T = const(23)
_U = const(24)
_V = const(25)
_W = const(26)
_X = const(27)
_Y = const(28)
_Z = const(29)
_1 = const(30)
_2 = const(31)
_3 = const(32)
_4 = const(33)
_5 = const(34)
_6 = const(35)
_7 = const(36)
_8 = const(37)
_9 = const(38)
_0 = const(39)
_ENT = const(40) # Enter
_ESC = const(41) # Esc
_BS = const(42)  # Backspace
_TAB = const(43) # Tab
_SPC = const(44) # Space
_MN = const(45) # Minus -/_
_EQ = const(46) # Equal =/+
_LB = const(47) # Left bracket [/{
_RB = const(48) # Right bracket ]/}
_BSL = const(49) # Backslash \/|
_SC = const(51) # Semicolon ;/:
_QT = const(52) # Quote '/"
_GR = const(53) # Grave `/~
_CM = const(54) # Comman ,/<
_DT = const(55) # Dot ./>
_SL = const(56) # Slash //?
_CAPS = const(57) # Caps lock
_F1 = const(58)
_F2 = const(59)
_F3 = const(60)
_F4 = const(61)
_F5 = const(62)
_F6 = const(63)
_F7 = const(64)
_F8 = const(65)
_F9 = const(66)
_F10 = const(67)
_F11 = const(68)
_F12 = const(69)
_PS = const(70) # Print screen
_SCL = const(71) # Scroll lock
_PA = const(72) # Pause
_INS = const(73) # Insert
_HOME = const(74) # Home
_PGUP = const(75) # Page up
_DEL = const(76) # Delete
_END = const(77) # End
_PGDN = const(78) # Page down
_AR = const(79) # Arrow right
_AL = const(80) # Arrow left
_AD = const(81) # Arrow down
_AU = const(82) # Arrow up
_LCT = const(128) # Left control
_LSH = const(129) # Left shift
_LAL = const(130) # Left alternate
_LSP = const(131) # Left super
_RCT = const(132) # Right control
_RSH = const(133) # Right shift
_RAL = const(134) # Right alternate
_FN = const(135) # Function
MATRIX = (
    (_1, _2, _3, _4, _5, _6, _7, _8, _9, _0, _MN, _EQ, 0, _BS, _INS),
    (_TAB, _Q, _W, _E, _R, _T, _Y, _U, _I, _O, _P, _LB, _RB, _BSL, _DEL),
    (_GR, _A, _S, _D, _F, _G, _H, _J, _K, _L, _SC, _QT, 0, _ENT, _PGUP),
    (_ESC, _LSH, _Z, _X, _C, _V, _B, _N, _M, _CM, _DT, _SL, _RSH, _AU, _PGDN),
    (_LCT, _CAPS, _LSP, _LAL, 0, _SPC, 0, 0, 0, _RAL, _FN, _RCT, _AL, _AD, _AR),
    (_F1, _F2, _F3, _F4, _F5, _F6, _F7, _F8, _F9, _F10, _F11, _F12, 0, 0, 0),
    (0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0),
    (0, _LSH, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, _RSH, _PGUP, 0),
    (_LCT, _CAPS, _LSP, _LAL, 0, 0, 0, 0, 0, _RAL, _FN, _RCT, _HOME, _PGDN, _END),
matrix = tuple(tuple(bytes(row) for row in layer) for layer in MATRIX)
pprint.pprint(matrix)
Actually initially I used that code directly, but then I decided to try and save a little bit more flash space (the code above takes almost no RAM, as it's all constants that are replaced in place with number literals).
 In any case, despite a few quirks (the modifier keys have to be present in both layers in the same places, for example) and a complete lack of software debouncing, it seems to work well.
As a final touch, I compiled a version of CircuitPython with all but HID USB devices disabled, so that it's only visible as a keyboard, and not a million other devices.
