How to Use Buzzer HW-508 with skiiiD
A tutorial to develop Buzzer HW-508(applicable for KY-006) via skiiiD
This project is an instruction of "how to use Buzzer HW-508(applicable for KY-006) with Arduino via skiiiD
Before start, there is a basic tutorial for how to use skiiiD
https://hackaday.io/project/167458-getting-started-with-skiiid-editor
We are working on components and boards libraries.
Feel free to use it and welcome to feedback. Below is contact methods
email: contact@skiiid.io
twitter: https://twitter.com/skiiiD_official
Facebook: https://www.facebook.com/enterphin
or visit https://skiiid.io/contact/ and go to Need help tab.
Comments are fine too!
  • 1 × HW-508(applicalbe for KY-006) Passive Buzzer
  • 1 × Arduino UNO / Nano / Mega
  • 1 × skiiiD Editor
  • 1
    Video Instruction
  • 2
    Step 1. Launch skiiiD and select Arduino UNO
    skiiiD Home
    #1 Launch skiiiD and select New button
    Select Board
    #2 Select ① Arduino Uno and then click ② OK button
    *This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have same process.
  • 3
    Step 2. Add Component
    skiiiD Code Editor Page
    #1 Click '+' (Add Component Button) to search and select the component.
    Search DotMatrix
    #2 ① Type 'Buzzer' on the search bar or find the Buzzer module on the list.
    Searched Result
    #3  Select Buzzer
    Pin Indication and Configuration
    #4 then you can see ③ pin indication. (You can configure it.)
    *This module has 2 pins to connect
    skiiiD Editor automatically indicate pin setting *configuration available
    [Default Pin Indication for HW-508 (or KY-006) Passive Buzzer] in case of Arduino UNO
    Signal: 3
    NC: NONE (Don't have to connect)
    GND: GND
    #5 After configuring pins ④ click ADD button on the right below side
    skiiiD Code Editing Page
    #6  Added Module has appeared on the right panel
View all 4 instructions
