Hot-swappable LED proof of concept
A project log for Project Healing Heart
The Healing Heart is a conflict-resolution tool which teaches children to apologize in a way far superior to most adults.
grant-stankaitisGrant Stankaitis 10/08/2019 at 05:490 Comments
I breadboarded my hot-swappable LED concept that I outlined in the last post. I attached an LED to male header pins and wired my Arduino up to a female header. I was able to remove insert and remove the LED to simulate fitting a heart piece into the base. This works surprisingly well, so I'm excited to implement it with pogo pins on a PCB! I have sourced 5V leds with built-in internal resistors, so this will eliminate the need for an in-line resistor with the LED, reducing the bulkiness of the design.
Crude soldering to header pins
LED lit up!!!
