Peristaltic Pump for Beverage Dispenser
Design, build and operate a Peristaltic Pump
aliAli
Public Chat
This is my final year project for my mechanical engineering course at university. The aim is to design, build and operate a Peristaltic Pump. I am planning to use an Arduino kit to operate the device and build it using my university facilities. If needed, will outsource complex parts. I will post updates on how the project is progressing. It will be very beneficial if the community can share their thoughts and opinions about the project.
Aim
The aim of this project is to design and construct an open-source pump for beverage dispensers that can also be remotely operated to reduce manual work needed by user.
Objectives
  • Select suitable pump type.
  • Design pump sketches and 3D drawings.
  • Construct Prototype for testing.
  • Test Prototype to identify any limitations and potential improvements.
  • Optimise design using analysis of prototype.
  • Construct pump base upon final design changes.
  • Install and connect micro-controller to allow for remote operation.
  • Test Pump to ensure the full desired functionality is available.
Pump Mark 3.rar
CAD parts and Assembly files for Pump Mark 3
RAR Archive - 2.04 MB - 03/24/2020 at 22:19
Download
stepper_motor_rotation_700.ino
Stepper Motor Arduino Code for Continous Rotation
ino - 886.00 bytes - 03/24/2020 at 15:32
Download
Prototype 2.rar
CAD parts and Assembly files for Prototype 2
RAR Archive - 1.05 MB - 03/24/2020 at 15:30
Download
Prototype 1 Components.rar
CAD parts and Assembly files for Prototype 1
RAR Archive - 1.22 MB - 03/23/2020 at 16:03
Download
  • 1 × Arduino Starter Kit Micro-controller
  • 1 × Nema 17 Stepper Motor
  • 1 × JOYLIT 12V 2A Power Supply Power Adapter Wall Plug
  • 1 × DRV8825 Driver Micro-stepping Bipolar Stepper Motor Driver
  • 3 × 608RS Ball Bearings Bearings (used as rollers)
View all 7 components
  • Design Improvement Ideas
    Ali04/28/2020 at 01:00 0 comments
    Electrical Setup
    Additional design improvements can also be integrated into the design’s electrical setup that can improve the pump’s convenience and provide additional features. For example, the electrical setup can be modified to incorporate a potentiometer knob. The knob can be rotated to adjust the input signal to the microcontroller which can automatically equate to changing the initially set flow rate value in the code. As a result, this will allow the user to adjust the flow rate during operation without the need to reconfigure the microcontroller’s code.
    An addition of a liquid crystal display (LCD) screen can allow the user to view details about the pump when running, such as the currently set flow rate or the operating time remaining.
    Furthermore, a toggle switch can be included to override the controller’s code and act as a safety off switch. It can alternatively be used to select between the controller’s codes. This can allow the pump to have separate functioning modes such as high and low speeds or small and large volumes. Enabling the user to quickly interchange between the modes depending on the desired task without the need to reconfigure the controller’s code.
    Design Optimisations
    Additional design upgrades can be implemented to improve the durability and functionality of the pump. For example, a plastic cover that can be fixed onto the top of the pump, shown in the figure below, can provide protection to the pump’s components such as the tubing and rotor. It can also prevent unwanted objects from entering into the casing, which can impede the rotor or tubing and can cause damage to them or leakage. The purpose of having a transparent cover is to enable the user to quickly inspect the inside of the casing for any potential leakage, thus improving the chance of identifying faults before they develop further.
    The number of inlet and outlet holes for the tubing can be increased, as shown in the figure below, from the current case where there is only a single inlet and outlet hole. This will allow the direction of the tubing to be adjusted according to the application’s need, which will reduce the risk of the tubing getting pinched due to sudden change in direction as it exits or enters the pump that can accelerate tubing wear.
    Finally, a housing for the electrical components can be created to contain the microcontroller and other fragile electrical components such as the motor driver and capacitor. This will give the design further durability and increase the project’s portability as the entire housing can be simply moved instead of each component separately.
  • Performance Analysis
    Ali04/28/2020 at 00:56 0 comments
    An estimate of the flow rate of the pump can be approximated from the rotational speed of the rotors and the cross-sectional area of the tubing. The flow rate is dependent on the fluid’s viscosity, tubing inner diameter, and backpressure. Therefore, the flow rate was calculated for a low viscosity Newtonian fluid in a pump setup with negligible back pressure or fluid elevation. The rotor is designed to compress the tubing to a distance of 2mm between the rotor’s tip and the wall of the raceway. Since the thickness of the tubing is 1mm, it is assumed that, at the point of compression, the tube walls are in complete contact and seal off the fluid. This means that no fluid is leaked backwards towards the inlet and that the rotor moves a fixed volume of fluid contained in the tubing. The total volume displaced in one revolution was be obtained:
    Volume per revolution = 0.000916 Litres
    RPM for 1.5 L/min =  1637
    Torque at maximum speed = 1.4N.cm
    The output torque of the motor was obtained using the motor’s torque-speed curve shown in the curve above. The output value of the torque was found to be about 1.4N.cm which is smaller than the required torque. Therefore, the pump will not be able to operate at such high speeds with the proposed setup. The pump’s maximum operating speed is approximately 1200rpm which will result in a pump flow rate of around 1.1 L/min instead of 1.5 L/min.
  • Finite Element Analysis
    Ali04/28/2020 at 00:51 0 comments
    The main component structurally analysed was the rotor as, based on previous prototypes, it is predicted to be a component highly susceptible to failure. The rotor was simulated under frictional loads transferred from the rollers that can likely initiate cracks in the rotor’s legs. However, the simulation estimated a factor of safety of 15, signifying that the rotor can withstand the frictional forces. Additionally, the maximum stress levels are at the centre of the rotor as shown in the figure below. This indicates that this area could be considered as the most likely to introduce failure, and as such should be regularly inspected during maintenance.
    Furthermore, the weight of the attached components on the rotor was simulated, not only to identify if failure is possible from the weight, but also to investigate if the weight will elastically deform the rotor leg, consequently altering the position of the rollers which can then collide with the casing. The analysis concluded that the displacement due to the weight is approximately 0.04mm, which is negligible and should have insignificant effect on the roller’s position as shown in the figure below. Additionally, the factor of safety was found to be around 11, which indicates that the weight will not affect the integrity of the rotor.
  • Costing
    Ali04/28/2020 at 00:29 0 comments
    The cost of the pump was evaluated to assess the design’s feasibility. The costs of the microcontroller, motor driver and power supply were not included in the analysis as they will still be needed regardless of the pump selected.
    Component
    Quantity
    Unit Cost (£)
    Subtotal (£)
    Casing
    0.132kg
    19.5/kg
    2.57
    Rotor
    0.012kg
    19.5/kg
    0.234
    NEMA 17 Motor
    1
    10.5
    10.5
    Tubing
    1 m
    1.40/m
    1.40
    Bearing
    3
    0.49
    1.47
    M3 bolt
    4
    0.05
    0.20
    M8 bolt
    3
    0.05
    0.15
    M8 Nut
    3
    0.08
    0.24
    Total
    £16.76
  • COVID-19 Impact on Project
    Ali03/24/2020 at 16:06 0 comments
    Due to the recent COVID-19 pandemic and health concerns my University has shut down all facilities and labs and as such I will not have the opportunity to construct my final design any time.
    I have decided instead to try and run some computational simulation on the Design for various analysis to understand, test and improve my design further. I am very open to hear ideas and feedback from the community with regards to my design.
    I will also try to temporarily fix the second prototype if possible and try to run practical tests on it as well.
    PS: I will still upload the CAD files for the final design for anyone who is able to print them and it would be amazing if you can share the progress.
  • Final Design CAD Sketches
    Ali03/24/2020 at 15:58 0 comments
    The main features changed from Prototype 2 are:
    1.Screw locations for the motor at the bottom of the casing. Allowing the motor to be easily removed and installed to the casing easily
    2. Fillets added to the sharp edges near the raceway to reduce the friction between the bearing and the walls of the casing
    3. Combined bottom and top rotors together to become one part this will ensure the distance between them is maintained at the desired amount
    4. Wedge feature include in the rotor to allow the attach to the motor shaft without the need of adhesion. This will not only allow the rotor to be removed when needed but also will offer better grip between rotor and shaft and prevent the shaft from rotating freely from the rotor
    5. Nut and bolt to be used to hold the bearings in place instead of rod as it offers a stronger structure and does not require adhesive to stick to the rotors
    Next Steps: I will next attempt to run various simulations on the design to validate its functionality.
  • Prototype 2: Testing
    Ali03/24/2020 at 15:16 0 comments
    Testing:
    Similar to Prototype 1, I tested this prototype using the same code that allows the stepper motor to continuously rotate.
    Testing at max motor speed had the same issue as the previous prototype as the torque is still lower than required at max speed. See video below of motor vibrating and struggling to rotate.
    https://vimeo.com/400265059
    However for this prototype, the motor was able to successfully pump fluid at lower speeds/ here is a video of the motor in operation ( with no tubing)
    I used a latex tubing instead the previous silicone tubing as it was more flexible. Additionally, after testing several times the adhesive between the shaft and rotors was removed and as such the motor shaft began rotating independently of the rotor ( similar to what has happened to the first prototype)
    i have also noticed that because the bearing height is not correct, they collide with a sharp edge in the raceway.
    Verdict:
    1. From Prototype 2, I concluded that the size of the casing and tubing seem to be sensible for the motor's output  and such will not be changed in the final design.
    2. Adhesive should not be used to glue rotor and shaft nor motor and casing as it makes it very difficult to disassemble.
    3. Maximum Motor speed should not be used as it significantly reduces the torque output and causes the components to rapidly vibrate that can then damage the structure.
    4. Need to add fillets to reduce sharp edges that slow down the bearings as they rotate.
  • Prototype 2: Construction
    Ali03/24/2020 at 14:48 0 comments
    Construction:
    1. First, I 3D printed the casing and rotors as intended. However the bottom rotor's extrusions were not successfully printed and as such I had to make some final minute adjustments to the design.
    2. I attached the motor to the casing using adhesive ( glue gun) as shown below.
    3. Then I carefully glued 8mm plywood rod in the bottom rotor and then inserted the rotor into the motor's shaft. The rotor's hole was tight enough to hold it in place on the shaft.
    4. Then I carefully slotted the bearings into the rods.
    5. lastly I aligned the top rotor with the rods and glued them together
    6. Finally I glued the rotors with the shaft.
    Conclusion:
    1. Using Adhesive to attach motor reduces the ease of disassembly in case a motor replacement is needed. It also reduces reduces the accuracy when horizontally aligning the motor.
    2.  Using Plywood as supporting rods for the bearing increases time and difficulty of assembly.
    3. Was difficult to align the rotors at the correct height as designed.
  • Prototype 2 Design
    Ali03/24/2020 at 13:17 0 comments
    Prototype 2:
    After constructing and testing Prototype 1 a new redesigned pump was sketched. The new design's aim was to reduce the limitations and inefficiencies of the first prototype.
    This was done through the following Features:
    1.  Reduce diameter of rotors to reduce the torque required by motor.
    2. Reduce overall height of casing to reduce material required and printing time.
    3.  Reduce thickness of rotors to reduce weight.
    4. Increase motor cut tolerance to ease assembly.
    5. Reduce raceway diameter to fit smaller tubing.
    Below are some CAD sketches for the new design:
  • Prototype 1 Testing
    Ali03/23/2020 at 19:12 0 comments
    Testing:
    First Trial:
    At my first trial to run the pump, the motor's shaft was disconnected from the rotors and as such was rotating independently and the rotors remained stationary as shown below. To overcome this, I used adhesive to stick the shaft and rotor together to be able to run the tests.
    Maximum Speed:
    The pump was tested at the maximum speed to see if the rotors are able to rotate through the casing and understand the potential max volume flow rate possible. Once the motor was operated, the rotors started rapidly vibrating in place as shown in link below. I assume this is because the torque supplied by the motor at such speeds is not sufficient to overcome  the frictional forces and moments the bearings experience from the casing's raceway.
    https://vimeo.com/user110521159/review/400015830/37903e3764
    Other Speeds:
    However, what I quickly realized is that even at slower speeds the rotor had difficulties rotating smoothly and while this can be due to manufacturing errors causes the rotor and casing to contact, this meant that if a tube was added the rotor will not be able to rotate at all.
    Verdict:
    Conclusion from testing the prototype is that:
    1. Size of the pump is too big for the motor to provide a reliable torque
    2.  Larger tolerance needed between rotors and casing
    3. Need to use more flexible tubing to reduce load required by motor
View all 17 project logs
  • 1
    CAD FIles & 3D printing
    Download the CAD files and 3D print the casing and rotor parts.
  • 2
    Stepper Motor
    Place the Nema 17 motor at the bottom of the casing and align the thread holes together. Then fix the 4 x M3 bolts to secure the motor
  • 3
    Rotor Fitment
    Align the rotor's orientation with the D-cut on the Nema 17 shaft. Insert the shaft into the rotor's hollow centre cylinder and push the rotor downwards until the end of the D-cut
View all 5 instructions
Sarah hossam wrote 04/23/2020 at 09:01 point
I made a project with stepper motors before. I would suggest you try some open-source codes that can save you time and effort.
Ali wrote 04/27/2020 at 23:59 point
Thanks I will have a look into this!
jenna wrote 04/23/2020 at 00:19 point
For the rotor issue, maybe try to make use of the shaft's d-cut instead of glue!
Ali wrote 04/28/2020 at 00:00 point
I have made such a mechanism. Please have a look in the project logs for the latest design updates.
Omar Yasser wrote 11/13/2019 at 18:20 point
Some fine ideas here Ali. What is the purpose of having a remotely controlled beverage dispenser?
Ali wrote 11/13/2019 at 22:16 point
Hello Omar, thank you for your question. Currently the idea is to use this feature to select and mix drinks together remotely without the user having to dispense different drinks several times ( Similar to the case when you use a typical soda tower).
However, I am sure I can also use the option for other features!
mohamed taha wrote 11/13/2019 at 16:50 point
Very interesting
