Prototype 1 Construction Notes
A project log for Peristaltic Pump for Beverage Dispenser
Design, build and operate a Peristaltic Pump
aliAli 03/23/2020 at 15:530 Comments
Construction:
I completed the construction of my first prototype (CAD drawings in previous log).
Assembly Steps:
  1. 3D Print Casing and Rotors
  2.  Fit bottom Rotor onto the motor's shaft
  3. Use Adhesive to attach Plywood rods onto the Rotor*
  4. Insert the Bearings onto the rods
  5. Use adhesive to attach the top rotor onto the plywood rods*
Issues and limitations:
