A tutorial to develop button module via "skiiiD"
#1 Launch skiiiD and select New button
#2 Select ① Arduino Uno and then click ② OK button
*This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have same process.
#1 Click '+' (Add Component Button) to search and select the component.
#2 ① Type 'Button' on the search bar or find the Button module on the list.
#3 ② Select Button
#4 then you can see ③ pin indication. (You can configure it.)
*This module has 3 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for Button Module] in case of Arduino UNO
Signal: 0
VCC: 5V
GND: GND
#5 After configuring pins ④ click ADD button on the right below side
#6 ⑤Added Module has appeared on the right panel
View all 4 instructions
skiiiD
Anıl Aras
4D Makers
akarshagarwal98
Yes, delete it Cancel
You are about to report the project "How to Use Button Module with skiiiD", please tell us the reason.
