ModbusRTU, lora 12km (real distance)
This my project test distance lora in case face to face, Unexpected results, reach 11.6km
Public Chat
The results of this project mainly come from the good quality of the equipment, the distance we achieved is because the lora module works well. I just integrated the modbus and lora into a PCB and then ran the test.The components include:-ESP32-LORA EBYTE E32 915T30D-Modbus RTU (max485, 74hc14D ...)-Power (LM2596, inductor, bridge mb6s, cap, res, fillter ...)-Auto upload code (Cp2102, c1815, micro usb ...)I have broadcast a packet containing 30 bytes with a transmit power of 30dbm, a speed of 0.3kbps. The distance I achieved was 11.6km. I couldn't move further because of space constraints. I think the best distance it can reach is over 15km.We can use frequency between 410 ~ 441MHz, 900 ~ 931MHz, 862 ~ 893MHz by changing the module
kurtklingbeil wrote 10/20/2020 at 05:12 point
very impressive
I'm trying to get modbus running via lora on an adafruit feather M0 with an RF95 I think radio
Dan Maloney wrote 10/15/2019 at 16:50 point
Even across open water like that, the range is pretty impressive.
