Mr. Robot shitty addon
perfect board to test the afterdark pcbs by oshpark
Perfect board to test the afterdark pcbs by oshpark. Supposed to be an I2C soundcard. No firmware yet.
MrRobotCode.zip
Code for master (anything) and slave (attiny)
Zip Archive - 2.80 kB - 11/17/2019 at 19:12
Download
saomr.pdf
Schematics for non-eaglers
Adobe Portable Document Format - 14.57 kB - 10/16/2019 at 12:24
Preview
Download
saomr.sch
Eagle schematics file
sch - 627.09 kB - 10/16/2019 at 12:23
See BOM
Download
saomr.brd
Eagle board file
brd - 269.18 kB - 10/16/2019 at 12:23
Download
  • 1 × Attiny85 SOIC
  • 1 × KMTG-1002 speaker
  • 1 × BC847 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × R1 4k7 1206 resistor
  • 1 × R2 2k2 1206 resistor
View all 8 components
  • Amplification by using inverted oscillator output
    davedarko11/18/2019 at 17:05 0 comments
    When I was talking with people about how some badges use two pins of the attiny, I basically explained it to myself while trying to explain to others why it would be louder. Instead of just pushing the speaker from the resting position, you also pull it back, when connecting both the inverted oscillator pins to a speaker. Now at the airport and thanks to seeing Charles Lohr at the supercon, I remembered that he actually did that. I need to further hack that bodged prototype I guess :D
    https://www.youtube.com/watch?v=__ECzxnvEg8
  • Hackaday Supercon updates
    davedarko11/17/2019 at 19:28 2 comments
    Friday night at supercon I decided to spend some time on the I2C part of the firmware. It's pretty simple, but I'm now able to send data from the #Penghicorn badge to this SAO and it will play a tone. Of course this can be further expanded, but I'm quite happy with the beeps. The speaker is very quite though and I need to take a look at other preferably surface mount speakers. Someone made a beeping R2D2 SAO and that has a nice speaker I want to check out.
View all 2 project logs
Frank Buss wrote 10/20/2019 at 04:29 point
Ok, I misunderstood your first answer that you just used his schematic. Makes sense now.
Frank Buss wrote 10/19/2019 at 12:38 point
davedarko wrote 10/19/2019 at 18:52 point
that's what I started with :)
Frank Buss wrote 10/19/2019 at 19:51 point
Might be a good idea if you credit the original author, but of course, he stole it from the movie, so maybe nobody cares :)
davedarko wrote 10/19/2019 at 22:22 point
@Frank Buss well it's a totally different schematic and what makes that PCB look the same is something none of us will ever claim as ours... it's an homage and he's aware of it. My first tweet about it was a picture with the Mr. Robot badge and I also tagged people. I had to redraw and import that image into eagle too, so excuse me when that wasn't my first agenda point.
