Smartwatch to Smartbracer
Turn my Samsung Gear S3 Frontier into a bracer that includes a 3000+ mAh battery, instead of it's original 380 mAh battery.
0 followers
My intention is to turn my Samsung Gear S3 Frontier Smartwatch into a Smartbracer. In the process, replacing the 380 mAh battery that sits within the watch's housing, to a 3000+ mAh battery that resides in a pouch in the bracer.
I have a couple older Smartwatches (Pebble, and Pebble Steel) I will use as guinea pigs for this project. I have already ordered 3.7v 3000mAh battery to test with the Pebbles, and a 3.85v 3000mAh battery for the Gear S3 if my idea pans out. I will prioritize the hardware portion of the project until I have a working concept. Then I will team up with a leather worker on the Bracer part.
Dan Maloney wrote 10/22/2019 at 16:13 point
Sounds cool, looking forward to the leather part.
