A project log for 6303 CPU card for RC2014
A 6303 based processor card for the RC2014 bus
etchedpixelsEtchedPixels 05/08/2020 at 18:030 Comments
The 6303 is a descendent of the 6303 so the question of 6803 support naturally comes up. As far as I can tell the only difference of relevance is that the 6303R has Vcc on pin 21 and a standby signal on pin 21, whilst the 6803 has Vcc on pin 7 and Vstandby (for the iram) on pin 21.
If I am reading the manuals right it should be sufficient to replace R4 with a wire link to run a 6803 processor. Once I have one to hand I will test.
