Knee Column kit for ramps in smd soldering heatpad.
Side view
toner transfer press configuration
transferring toner.
toner transfer
results of toner transfer.
Photo Addendum: Using MDF as a thermal barrier to slow down temperature loss through similarly conducting surfaces doesn't give you a good result!
