Micro Instructions
A project log for Nits Processor
8-bit TTL technology processor
cedCed 11/19/2019 at 10:220 Comments
All the initial modules are now built, it is time to document the list of Micro Instructions.
Here is a map of all the available Micro Instructions assigned to each modules:
[unless specified, all actions are synchronous on the CLOCK_MAIN clock signal]
A register
B register
ALU & Flags
Instruction register
Step counter
Clock
Program counter
Memory Address Register
Memory
Output Register
Some of these signals will be connected to the Instruction Decoder, some are connected to the reset switch only.
