| Name | Part Number | Qty. |
| Nema 8 Bipolar 1.8deg 4Ncm (5.7oz.in) 0.6A 6V 20x20x38mm | 8HS15-0604S | 1 |
| Nema 11 Bipolar 1.8deg 7Ncm (9.91oz.in) 0.67A 3.8V 28x28x31mm | 11HS12-0674S | 2 |
| Nema 17 Bipolar 1.8deg 44Ncm (62.3oz.in) 0.85A 5.3V 42x42x48mm | 17HS19-0854S | 2 |
| Nema 17 Bipolar 1.8deg 60Ncm (85oz.in) 0.64A 10V 42x42x60mm | 17HS24-0644S | 1 |
| Geekcreit® RAMPS 1.4 Control Board + MEGA2560 R3 + A4988 Driver With Heat Sink 3D Printer Mainboard Kit | | 1 |
| 3D Printer 42 Stepper Motor Drive Expansion Board 8825 / A4988 | | 1 |
| 40pcs 20cm Female to Female Jumper Cable Dupont Wire For Arduino | | 1 |
| Geekcreit® 3D Printer Stepstick DRV8825 Stepper Motor Driver Reprap 4 Layer PCB | | 1 |
| PSU ~200W, I am using a Liteon ps-5221-06 PC power supply | | 1 |
| Emergency Stop Switch LAY37 | | 1 |
