infrasound_monitor_program_files.zipRaspberry Pi Infrasound Monitor -- program files and installation instructions -- updated 1-June-2023Zip Archive - 321.96 kB - 06/01/2023 at 18:21 |
InfrasoundMonitorPresentation.pdfAn overview of the systemAdobe Portable Document Format - 6.69 MB - 05/19/2020 at 13:18 |
spiralfoam.jpgComparing two windfilters, foam block and porous hose.JPEG Image - 287.61 kB - 04/26/2020 at 12:45 |
ConstructingInfrasoundMonitor.pdfFull construction detailsAdobe Portable Document Format - 6.30 MB - 04/20/2020 at 15:38 |
seamerFourier.pngSignal from near wind turbine showing fundamental frequency (0.7Hz) and harmonics.Portable Network Graphics (PNG) - 69.95 kB - 10/20/2019 at 10:25 |
sabic2.png4 day plot of acoustic power (0.05-2Hz). Region between red and blue vertical lines is signal due to a chemical plant 'flaring' approx 10km away.Portable Network Graphics (PNG) - 114.97 kB - 10/20/2019 at 10:16 |
wavelet_transform_2018-07-27.pngContinuous wavelet transform of a reading.Portable Network Graphics (PNG) - 100.79 kB - 10/20/2019 at 10:11 |
porous_hose_seamer_sml.jpgUse of porous garden hose as wind filter outdoorsJPEG Image - 72.51 kB - 10/20/2019 at 10:11 |
infraproto1.pngInitial sensor casing - aluminium case at bottom is a pneumatic filter to eliminate pressure variation with a period above ~100sPortable Network Graphics (PNG) - 223.83 kB - 10/20/2019 at 10:11 |
JPEG Image - 141.38 kB - 10/20/2019 at 10:08 |
