t85bauble_c.zipContains the source code and compiled hex file that rotates though all LEDs. Compatible with all board revisions. Recommended not using a CR2032 to power due to relatively high continuous current.x-zip-compressed - 6.05 kB - 03/06/2020 at 19:02 |
t85bauble1_1.zipContains the source files and compiled hex file that blinks an LED every 4 seconds and runs for about 30 minutes.x-zip-compressed - 6.45 kB - 03/06/2020 at 18:59 |
t85bauble1.1.zipIncludes the KiCad and Gerber files of the revision 1.1 board.x-zip-compressed - 65.14 kB - 03/06/2020 at 18:42 |
t85bauble1.1Gerbers.zipJust contains the Gerber files of the revision 1.1 boardx-zip-compressed - 16.59 kB - 03/06/2020 at 18:41 |
t85bauble_firmware.zipcontains both the source code and the compiled hex file for the attiny85x-zip-compressed - 6.14 kB - 11/05/2019 at 23:37 |
t85bauble_gerbers.zipJust contains the Gerber files of the revision 1.0 boardx-zip-compressed - 16.72 kB - 11/05/2019 at 23:35 |
t85bauble.zipIncludes the KiCad and Gerber files of the revision 1.0 board.x-zip-compressed - 56.64 kB - 11/05/2019 at 23:34 |
