Hex-O
Eight RGB LEDs in a circle, two matte-black hexagon PCBs and one SAMD micro for fun, decoration, meditation or whatever.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Starting from
$28.00
ndgarage has 42 orders / 3reviews
Ships from Canada
Hex-O has two matte black PCBs in the shape of hexagon. One PCB has 8 back-soldered RGB LEDs in a circular pattern. The LEDs are driven by a programmable SAMD20 micro-controller. The other PCB has a CR2032 battery holder.
The hexagon is about 40mm by 36mm. The length of each side is about 20mm and the diagonal length is 40mm. Hex-O could be assembled together easily with M3 Hexagon nuts.
