MCU
A project log for MIPI-HDMI Bridge RE
Reverse-Engineering a random MIPI-HDMI bridge from China
Jared SansonJared Sanson 10/29/2019 at 05:258 Comments
As explained in previous logs, the MCU is the brain of the board. It configures the HDMI bridge chip, and handles power-sequencing of the display.
Out of curiousity, I connected an STLink to the SWD pads on the PCB, and behold, the chip is unlocked!
This allowed me to extract the firmware. I plan to reverse-engineer the firmware to determine how it configures the system, and how it could be configured via USB.
GPIO map:
---------- more ----------
Label
MCU Pin
MCU Port
Net Name
Supply Voltage
E1
31
PA10
VDD_HDMI
1.1v
E2
14
PA4
VDD_MIPI
1.2v
E3
11
PA1
VDD33_HDMI VDDIO33
3.3v
E4
30
PA9
VDD_DISP_18
1.8v
E5
42
PB6
VDD_BL (V3)
E6
13
PA3
VDD_DISP_33
3.3v
E7
17
PA7
VDD_OLED (V1/V2)
+V/-V?
E8
43
PB7
VDD_BL (V3)
E9
45
PB8
Feedback?
E10
29
PA8
VDD_OLED (V1/V2)
+V/-V?
L1
16
PA6
LED1
L2
15
PA5
LED2
A
21
PB10
IOA (1.8v)
B
46
PB9
IOB (1.8v)
C
25
PB12
IOC (3.3v)
D
22
PB11
IOD (3.3v)
B1
28
PB15
BTN1 (Left)
B2
27
PB14
BTN2 (Right)
(Ignore the labels column - I am using it within my reverse engineering to track the signals)
Flash Layout
0000 0000
Boot Space (Aliases to one of the below regions)
0800 0000
Flash space
1FFF F000
System memory space
2000 0000
SRAM space
1FFF F7D6
USART Bootloader
Nout wrote 12/19/2020 at 18:32 point
Actually I found you can just press the button closest to the DSI connector while plugging the USB, and the MCU will enter DFU mode, from which you can upload and download firmware. Mine wasn't read protected either, so I was able to backup the original firmware.
However it looks like the I2C bus is connected to pins 40 and 41 of the MCU, which are not muxltiplexed to the I2C module, so I'm wondering if they are bitbanging the bus .. will have to get a closer look with an oscilloscope.
l33tn00b wrote 01/02/2021 at 18:34 point
Yup. Took a quick look at the hex file. Couldn't identify the use of the "real" I2C Peripheral Registers...
Rahul wrote 06/15/2020 at 13:18 point
Hi Jared,
I have a 4k MIPI board and tried connecting to it through ST-Link but wasn't able to access / read .  SWD Pads were connected in following order:
Pad-1: 3.3v, Pad-2: GND, Pad-3: SWDIO, Pad-4: SWCLK.
Error: Target Detection Failed.
Any idea what I may be missing here?
ellimtl wrote 02/05/2020 at 20:04 point
Hi Jared,
Thank you for your reply. I found them.
Regarding the chip unlock, you have said "I connected an STLink to the SWD pads on the PCB, and behold, the chip is unlocked!"
Which STLink model you've used? Does this model work?
https://www.amazon.ca/STLINK-V3SET-Modular-debugger-Programmer-STM32/dp/B07MB9TKDX/ref=sr_1_fkmr0_1?keywords=STLINK+Modular+in-Circuit+debugger+and+Programmer+for+STM32&qid=1580932804&sr=8-1-fkmr0
Can you please introduce your STLink that was functional on this board?
Thanks and regards,
Daryon
Jared Sanson wrote 02/06/2020 at 05:33 point
I'm just using the STLink built into my STM32Discovery board, not a standalone programmer. I'm not an expert on STM32 but I think almost any STLink should work on this chip, so just get the cheapest one you can find. You definitely don't need to spend $90 on one :)
ellimtl wrote 02/04/2020 at 21:18 point
Hi Jared,
Thanks for the nice job! I followed your post and got stuck here! How can we access to the firmware uploaded to the chip?
Thanks and regards,
Daryon
Jared Sanson wrote 02/05/2020 at 02:27 point
Hi, you can find the firmware dumps under 'Files' on the main project page. No guarantee this is a complete dump...
https://hackaday.io/project/168212-mipi-hdmi-bridge-re#menu-files
l33tn00b wrote 01/02/2021 at 18:35 point
Looks good, though. Ran it through Ghidra (Little Endian, Cortex, Thumb), gives a nice disassembly.
