Display Connector
A project log for MIPI-HDMI Bridge RE
Reverse-Engineering a random MIPI-HDMI bridge from China
jared-sansonJared Sanson 10/29/2019 at 05:190 Comments
The connector provides two independent MIPI channels, each with 4 data pairs & 1 clock pair. The 5V rail is always powered, but the other rails can be individually sequenced and controlled by the MCU. The GPIOs can be used to control additional regulators or enable control signals on the display board. They are output only.
I do not know what chip "ET7" and "MH 23 22" are, but they are obviously some kind of buck regulator. A/B/C/D are the GPIO control signals from the MCU (output only).
E6 enables the 3.3v rail, and supplies the 1.8v regulator. IOC/D are powered even if this rail is not.
E4 enables the 1.8v rail to the display connector, but only if E6 is also enabled (for 3.3v). IOA/B are pulled-up to 1.8v if this is enabled.
The 5V rail is always powered.
I am not sure what the deal is with the chip at the top that is fed directly from +5v.
TFT Backlight Driver
For TFTs, there is a dedicated backlight driver:
V3 is +V for the backlight, and either FB1/2 can probably be chosen for -V depending on the drive strength that is desired.
E9 is obviously an analog feedback signal to the MCU for controlling the drive current, E5 is the main supply enable, and E8 is probably a PWM control signal for defining the drive current.
OLED Bias Voltage
E7 enables the bias circuit.
E10 is probably a PWM drive signal for controlling display brightness.
On my board, the following signals come up in this order when it is powered on:
A: Slow Flashing Blue LED / Initial power-up
B: Fast Flashing Blue LED
C: Green LED
You can see that on my board, the LED backlight & OLED bias supplies are never turned on. Instead the dsplay board has it's own regulators which are controlled by the IOA/B/C/D GPIOs.
Full connector pinout:
Number
Net Name
Voltage
Breakout Net
Use
Description
1
FB1
Feedback 1
2
FB1
Feedback 1
3
4
5
FB2
Feedback 2
6
FB2
Feedback 2
7
8
V3
Backlight
9
V3
Backlight
10
V3
Backlight
11
12
GND
13
V1
OLED Bias (E7+E10 Ctrl)
14
V2
15
16
17
18
19
IOA
1.8
G
Right OLED Enable?
E4 Ctrl
20
IOB
1.8
F
Right OLED Enable?
E4 Ctrl or Always powered?
21
22
V_1.8
1.8
E
1.8v Supply
E4 Ctrl
23
24
V_3.3
3.3
N
3.3v Supply (1st)
E6 Ctrl
25
V_3.3
3.3
N
3.3v Supply (1st)
E6 Ctrl
26
V_5.0
5.0
USB VIN, Always powered
27
IOC
3.3
L
Enable OLED Bias (2nd)
Always powered
28
IOD
3.3
M
Enable 2.8v Supply (1st)
Always powered
29
30
GND
31
DSI0_D0
D
32
DSI0_D0
D
33
GND
34
DSI0_D1
35
DSI0_D1
36
GND
37
DSI0_C
C
38
DSI0_C
C
39
GND
40
DSI0_D2
41
DSI0_D2
42
GND
43
DSI0_D3
44
DSI0_D3
45
GND
46
DSI1_D0
B
47
DSI1_D0
B
48
GND
49
DSI1_D1
50
DSI1_D1
51
GND
52
DSI1_C
A
53
DSI1_C
A
54
GND
55
DSI1_D2
56
DSI1_D2
57
GND
58
DSI1_D3
59
DSI1_D3
60
GND
