• Survived the night
    Kyle Isom11/02/2019 at 20:59 0 comments
    The battery lasted through the night, and it's still alive and transmitting.
    There were some humidity readings that seemed high this moring; I went to check for moisture in the enclosure but didn't see any.
    My readings were higher than the weather.gov readings for my area, but I'm near a boundary of the area, so I'm not sure how that affects things. I'd like to start keeping a notebook of outdoor electronics projects to learn how to build more durable, sustainable systems.
  • V1
    Kyle Isom11/02/2019 at 01:09 0 comments
    I'm calling this completed for now; I have to let it run, and I will likely come up with (or people might give me) improvements, but it appears to be working for now.
  • Are you receiving?
    Kyle Isom11/02/2019 at 00:41 0 comments
    Transmission received.
    The sun's going down, so we'll also find out how well the battery lasts overnight.
    And I just received the second measurement, so things are looking good so far...
    Kyle Isom11/02/2019 at 00:37 0 comments
  • Collector running
    Kyle Isom10/30/2019 at 19:50 0 comments
    Still having uplink issues, but I've got a collector now to stash any uplinks that make it out. The goal is to move this to a raspi but for the sake of having it running now, this works.
  • Transmission errors
    Kyle Isom10/29/2019 at 23:37 0 comments
    I'm running into constant issues with the node getting stuck trying to join the network.
    I'm trying to debug this, but I wonder if it isn't because the USB port is only getting 3.7V, not 5V - I don't think it *should* matter, but it just might.
  • Basic sensors working
    Kyle Isom10/29/2019 at 22:52 0 comments
    Got it sending to TTN.
    ~/tmp/scratch
    (0) <hephaestus:kyle> $ ./tr.py E3070A1D0B1E040FAB080000AF479D411C85F34000AAF441C27BC6473F0200001A000000FD0001
    (2019, 10, 29, 11, 30, 4, 15, 2219, 19.660001754760742, 7.60999870300293, 30.5830078125, 101623.515625, 575, 26, 253, 0, 1)
    year: 2019
    month: 10
    day: 29
    hour: 11
    minute: 30
    second: 04
    hardware: 15
    uptime: 2219 seconds
    temperature: 19.660001754760742 °C
    calibration temperature: 7.60999870300293 °C
    humidity: 30.5830078125%
    baro pressure: 101623.515625 Pa
    CO2 levels: 575 ppm
    TVOC levels: 26 ppb
    voltage: 253 [junk value]
    CCS811 status: 0 (no error)
    Calibrated? 1 (temperature calibrations are in effect)
