PCB Revision 2 Arrived and Tested!
A project log for Speak&SID CPC
A Speech Synthesizer, SID Soundcard, and MIDI IN Realtime SID+AY Synthesizer for the Amstrad CPC!
Michael WesselMichael Wessel 12/02/2019 at 03:250 Comments
It was bugging me that the previous PCB revision had the SID chip upside down. So I bit the bullet and rearranged the layout a bit. The new PCBs worked out of the box. I also added GND copper fill to the PCB bottom (not sure it makes a difference, but seems to be good PCB design practice). Saifisfied with the PCB now, and declaring the hardware side of this project as done.
