Quadruped Pumpkin
Don't just have a Jack-o-Lantern sit motionless on the porch! Give it some life and limbs!
Much like Frankenstein's monster, pumpkins become more interesting once electricity becomes involved. My goal for this year's custom Halloween decoration was to create a seemingly normal pumpkin that when prompted will extend its legs and reveal that it is in fact a robot in disguise.The robot uses 8 servo motors to actuate the legs. In its current version it can only extend and retract its legs to stand itself up and return itself to pumpkin form; in a future update I intend to add four more to give the robot the ability to walk around. Unfortunately, the adhesives used to secure the plastic skeleton to the foam leg pieces created a weaker connection than I anticipated so in the attached media files the pumpkin is propped up on a stand so the legs aren't supporting the body. Although the servos are powerful enough to stand the robot up the leg pieces would likely need additional support to endure
Dan Maloney wrote 11/05/2019 at 15:49 point
A jack-o'-lantern that stands up and chases you around the porch would be a pretty intense Halloween decoration. Looking forward to the Nest footage next year...
