Code_contribution_from_Ryan_Hashiro.ino
The original code for the turntable but modified by Ryan Hashiro:<br>1. Added library calls and setups for an LCD with I2C backpack.<br>2. Added fast value change routines for the number of photogrammetry pics, motor speed, and cinematic turns. Holding joystick deflection for > 1 sec enters fast change mode. Change rate is proportional to amount of deflection. For the motor speed change is fixed at the slow speed since there's only 17 values to go through.<br>3. Added cancel routines for the photogrammetry and cinematic modes. Holding the joystick button down for > 2 sec kicks you out of the operation modes.
ino -
22.90 kB -
08/25/2020 at 21:02
