Updated wiring diagram
A project log for Arduino controlled photogrammetry 3D-scanner
A completely automated way to take photo's and convert them into a 3D-object
brian-brockenBrian Brocken 11/24/2019 at 20:170 Comments
Made a very small adjustment in the wiring diagram to avoid possible confusion with the 5V and Vin pin. I changed the color of the Vin wire to orange, the 5V and Vin wire should not be connected together. The 5V wire goes up to the LCD,  joystick and potentiometer. The Vin wire goes to the DC-DC step down voltage regulator.
