• Starting ...
    Edgar Kogler11/10/2019 at 17:41 0 comments
    5.11.2019
    I disassembled the iron and started choosing the controlcircuit and a fitting thermistor.
    Since thermistors ready for 300°C are rather expensive I chose one with 150°C limit.
    An alternative solution seemed to use an existing thermostat from an baking oven, but they are too big for my purpose.
    10.11.2019
    I chose the circuit of Oliver Pering:
    http://hobbyelektronik.de/praxis/projekte/temperatur-schaltstufe/
    I had a nice time calculating resistor values for the voltage dividers used to switch the heating via the OpAmp (the good old workhorse, a historic LM741 ;-) )
