Created connector board
A project log for S_Drive - small BLDC driver
S_Drive is small bldc driver based on L6234 Three phase motor driver.
petar-crnjakPetar Crnjak 07/25/2020 at 15:230 Comments
Connector board can be used to make easy connections to BLDC driver. It has RS485 chip onboard, so you can communicate with UART and RS485.
As you can see on this picture S-drive uses only one cable for everything; data and power. Daisy chain is really easy to make with these drivers and everything can look clean and compact.
