Kinematic Yokes for Bed - Part 2
A project log for MechaCore - Railcore Inspired 3D Printer
I started to build a RailCoreII ZLT printer, but decided to give it a once-over and fix/update everything I don't like, keeping what works.
patrickPatrick 11/19/2019 at 03:061 Comment
Picking up with the Kinematic Z Yokes, I've created the 3 versions. I labeled them A, B & C.
Ball A will pin the bed at the A-corner as the ball rests inside 3 pins
Ball B will be allowed to move linearly in the Y axis as it rests between 3 pins
Ball C will be allowed to translate on X or Y
Above are the 3 Z yokes, all derived from a master version.
The ball would be an 8mm diameter or 5/16 inch. https://www.amazon.com/7-938mm-Silicon-Nitride-Ceramic-Bearing/dp/B07D8VQ2GB/. Ceramic has low thermal conductivity, SiN4 has a thermal conductivity as low as 10 W/m-K.  I could go with glass spheres as well.
The pins are all 2.5mm, and either 8mm long or 20mm long.
Here is the assembly, it will tolerate a fair amount of angular misalignment without binding, not really planning on allowing a worst case situation.
Z axis kinematic mount printed in Onyx w/Carbon
Emily B wrote 02/29/2020 at 05:49 point
how’s this working out for you? Would you be willing to post the STL files in the gh repo?
