Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
3D Printed FM Radio using Arduino
FM Radio using RDA5807 FM Radio Tuner IC and Arduino
Neeraj RaneNeeraj Rane
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
241 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
247
0
241
8
Team (1)
  • Neeraj RaneNeeraj Rane
Join this project's team
hardware
completed project
fm radio arduino RDA5807 3D printed audio MUSIC
This project was created on 11/12/2019 and last updated 3 years ago.
Description
Recently, I came across the RDA5807 module which is an FM Radio Tuner in a very tiny package. It is very cheap and uses the I2C protocol for communication which means that only two wires will be required to talk to the IC. Less wiring!
My mom used to listen to the radio every day while cooking food before the radio died. I wanted to surprise her with a radio which I built myself. To make it look good, I designed an enclosure and 3D printed it. I'm new to 3D designing so it is a simple design. No fancy stuff.
Details
Log In/Sign up to comment
Sign up with Github
OR
Studio Grip system using Golf Balls, all thread and 3d printed parts.
Project Owner Contributor
Golf Ball Grip. Studio and Lighting Gear System
Jesse SchochJesse Schoch
radio controlled functional forwarder HSM 208F
functional Forwader HSM 208F in scale 1:87
oliver.praxoliver.prax
Reduce weight and build a Yagi antenna using your hiking pole and Arrow Antenna elements
Hiking Pole Yagi Antenna
Stuart, KB1HQSStuart, KB1HQS
A Fully 3D Printed Arduino Robot Arm for STEM Education
LittleArm 2C: 3D Printed Robot Arm
slantconceptsslantconcepts
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "3D Printed FM Radio using Arduino", please tell us the reason.
Send message
Remove Member
