18650 Cell Cooling Experiments
Testing temperature rise of Samsung INR18650-25R cells under load and the effects of water cooling.
I want to build a large battery pack for an electric super bike. My goal is top speed and power rather than range. As such the battery pack will be pushed to lit's limits. I intend to investigate the temperature rise of 18650 cells under their peak rated load, and whether an effective water cooling system could be manufactured from commonly available materials.
My test setup consists of the following parts which were all built for this project:
Battery pack:
The battery pack consists of 4 Samsung INR18650-25R cells mounted in a wooden frame. The cells are spaced 3.5mm apart to allow cooling pipework to be installed. The cells are connected in series via spot welded nickel plated steel strips. Three 10KNTC thermistors measure the following:
  • Cell at edge of pack
  • Cell at centre of pack
  • Centre nickel strip
The power connection to the battery pack is via 14AWG silicone cables to an XT60 connector to allow disconnection in an emergency.
During testing the battery pack was insulated from its surroundings to simulate being in the centre of a larger battery pack (all local cells would be at the same temperature so no movement of energy)
Above: Battery pack with cooling tubing and temperature sensors
Water cooled dummy load:
This horrible looking device is a high-power Mitsubishi QM300HA-2H triple FET (salvaged from a vintage motor drive) fixed to a water cooling block along with a .05ohm current sense resistor. An op amp and MOSFET provide the not insignificant current required to drive the triple. A potentiometer provides current adjustment. The water-cooling block is fitted with a shower hose to allow the device to be easily coupled to the shower in my bathroom.  The device would be set to discharge the battery at 20A which is the maximum continuous rated discharge of the cells. The dummy load did occasionally oscillate causing the current to be uncontrolled. This requires further investigation. Discharge current was monitored with a clamp meter throughout the testing.
Please note this was a quick and dirty way to get the job done. Not my finest work!
Above: Water cooled dummy load. Spanner provides clamping tension
Arduino Data Logger
An Arduino controls the test period and monitors the battery voltage and temperature. The Arduino communicates with a laptop via the USB serial port. Putty is used to send commands to the Arduino to start the test. Once the test has begun data is streamed to the laptop which can be logged to a file and later imported to excel. The Arduino will stop the test if any of the temperatures exceed pre-set limits or the battery voltage falls to low.
Above: Serial data during test
Water cooling system
The water-cooling system consists of a car windscreen washer pump. It is a generic item from ebay, not a specific manufacturer as far as I can tell. It is a gear pump intended to run on 12V. It quickly became apparent that the pump is not rated for continuous operation at 12V. The motor gets very hot. All tests were carried out with the pump running at 6V. Even at 6V the motor gets to alarming temperatures. I would suggest using a better pump for similar experiments.
A measured quantity of water is stored in a glass jug which is pumped through the battery. The temperature is monitored via a brewing thermometer. The jug was not insulated so can gain energy from its surroundings as well as the energy removed from the battery.
Flow rate is approximately 330ml/minute
Above: Ebay pump. Do not use.
Thermal interface to cells – 4mm pneumatic hose
The cells were placed in the mounting frame to allow 4mm pneumatic hose to be threaded between them. Each cell is covered by 7 180° wraps of tube (later increased to 12). Coupling is poor due to the round outside diameter of the tube. All testing to date has used this method
Above: Pneumatic tube threaded around cells
Thermal interface to cells – 25mm lay flat hose
25mm lay flat hose was chosen because it could be threaded between the cells providing a much larger surface area of contact. The ends of the hose were coupled to the pump via barbed fittings soldered to copper plumbing end caps.
Thermal testing with this method was not attempted. The walls of the lay flat hose are very thick and the hose crumples as it is passed around the outside diameter...
Adobe Portable Document Format - 39.10 kB - 11/15/2019 at 09:22
Preview
Download
ino - 14.86 kB - 11/15/2019 at 09:16
Download
Adobe Portable Document Format - 43.53 kB - 11/15/2019 at 09:16
Preview
Download
  • Initial Results - To be continued
    Rory11/14/2019 at 22:44 0 comments
    Test 001 - 10A No Water Cooling
    • Had to set current pot at start so first few seconds values are unreliable
    • load set to 10A
    • No water cooling
    • Cells insulated with tea towel to simulate being in centre of pack
    • Glue on tape securing cell temp sensors softened towards the end. Sensors could move away from cells. This may have been giving unreliable readings
    • Cut off at 2.5V per cell, 80°C on busbar and cells
    • Test ended due to low voltage
    Test 002 - 10A No Water Cooling
    • load set to 10A
    • no water cooling
    • cells insulated with tea towel to simulate being in centre of pack. Wrapped more tightly since test 001
    • sensors now firmly fixed to cells
    • cut off at 2.75V per cell, 80°C on busbar and cells
    Test 003 - 10A With Water Cooling
    • load set to 10A
    • water cooling on, 0.5l water start temp 26°C finish 28°C.
    • ended due to low voltage
    • Cell temperature significantly reduced from earlier tests with no cooling.
    Test 004 - 10A With Water Cooling
    • load set to 10A
    • water cooling on, 0.5l water start temp 26°C finish 29°C.
    Test 005 - 20A With Water Cooling
    • load set to 20A. (was set to 10 at start of test, had to set pot, hence gradual fall in voltage at start of test)
    • water cooling on, 0.5l water start temp 25.5°C finish 28.2°C.
    Test 006 - 20A With Water Cooling
    • load set to 20A
    • sensors now re positioned into wooden frame and replaced with bead sensors (smt thermistors easily damaged)
    • Something has happened to dummy load or data logger. Spurious voltage reading.
    Test 007 - 20A With Water Cooling
    • load set to 20A
    • water cooling on, 0.5l water start temp 25.0°C finish 29.0°C.
    • sensors now repositioned into wooden frame and replaced with bead sensors to allow space for more cooling tube coils 12 rows of cooling coils (previously 7)
    • checked connections from previous test but voltage reading still suspect.
    Results
    The method of cell cooling using wraps of pneumatic hose clearly has some useful effect. During 10A testing the peak temperature was 60°C without cooling, 42°C with cooling.
    During the 20A testing the temperature peaked at 62°C with cooling and 7 180° wraps per cell. Increasing wraps to 12 reduced temperatures to 56°C.
    I have yet to test a 20A discharge with water cooling disabled. May have to keep a fire extinguisher handy. Will update soon.
    Other thermal coupling methods are to be tried also
View project log
