Thanks so much to @Michael Welling for finishing routing the badge.
Michael used 2 layers for the initial prototypes so we can fab them faster. There are only 8 weeks left until the Open Hardware Summit on March 13th.
https://github.com/oshwabadge2020/Badge-PCB/pull/14
For those without KiCad:
Gerbers:
https://github.com/oshwabadge2020/Badge-PCB/tree/master/gerbers
Schematic PDF:
https://github.com/oshwabadge2020/Badge-PCB/tree/master/schematic.pdf
OSH Park renders:
Here is PDF of layer preview from OSH Park:
https://hackaday.io/project/168483-open-hardware-summit-2020-badge/files
ZIP of the layer renders:
https://cdn.hackaday.io/files/1684837208376672/OSH%20Park%20_%20Verify%20your%20design.zip
OSH Park shared project has hi res top and bottom render:
