• Following the Map
    jlbrian7 • 11/17/2019 at 19:47 • 0 comments
    My phone showed that I was able to closely follow the custom map, but what the GPS logged showed a different story.  Here is the output uploaded to Strava:
    and by going to the Garmin connect site it is possible to download the track in a GPX format, which can be imported into qgis as a vector file.
    Here the logged datapoints are off by about 25' to 35'.
    So, the next step will be to follow a custom map while logging the gps on my cell phone, and see how far off the datapoints are there, in relation to the map.
  • Refining the Process
    jlbrian7 • 11/17/2019 at 19:38 • 0 comments
    The next step was to create an interactive map, and test the capabilities of the Garmin device, just to see what could be accomplished.
    I grabbed an image off of a google search, opened it up in Gimp, and cleaned it up so that I just had the lines that I wanted:
    After I was happy with what I had I exported the image as a .tif, and then went to qgis.
    First I added an OpenMaps layer, and then imported the .tif image using the Freehand raster georeferencer plugin.  This made it easy to position the image where I wanted to walk, since there was no geo info with the image I just created.
    Now that the image is in place, a layout is created, and saved as a pdf, which was then transferred to my phone, and imported into the Avenza Maps app.
  • First Attempt
    jlbrian7 • 11/17/2019 at 19:25 • 0 comments
    Here I placed a png of pacman over a portion of Galveston, and just tried to follow it the best I could.  It was pretty terrible.
    Here is the data that was captured, and uploaded to strava:
