LoRaWAN Feather
An Adafruit-compatible, LoRaWAN-compatible board.
A LoRaWAN Feather board based on the STM32L073 and DRF1262T radio module. Has all the awesome Feather features:
- USB
- LiPo charging
- I2C, SPI, UART, GPIO, Analog, DAC
- USER button and LED
With all the fun LoRaWAN features
- STM32L073 and SX1262 supported configuration for the Semtech LoRaWAN reference
implementation
With awesome upgrades!
- Efficient DC-DC buck/boost converter
- SWD connector
- Builtin LiPo Fuel Gauging
- Hardware support for a hard secure element
Designed to be machine built. Most of the PCB is, in fact, designed around the JLC SMT parts library.
Designed to meet the Feather spec and with LoRaWAN library compatibility in mind from the start.
Designed to be compatible with STM32CubeMX.
Should be hand buildable for anyone with some soldering skill if you want to get all the design files yourself.
Open source from the start!
Find the hardware on GitHub
Find the firmware on GitHub
PCB is laid out according to the Adafruit Feather spec.  The idea is to make it manufacture-able.  It could be sold as a finished board minus the headers, RF connector and the radio module.  All of those parts are easily hand solder-able.
The radio module is by Dorji and is the DRF1262T.  It's FCC certified and is available on Tindie.  The module is based on the SX1262.
The board implements I2C, SPI, UART pins.  Implements 4 GPIO (one is connected to the SPI hardware NSS pin).  Implements 3 analog pins, one is a DAC pin.  The STM32L073-SX1262 combination is an out of the box supported configuration by the Semtech LoRaWAN reference implementation.  Has hardware support for the hard secure element.  Includes native USB with ESD protection and common-mode filtering.   Includes an efficient DC/DC buck boost based on the TPS63001 capable of supplying ~300mA@3.3V.  Includes the 2x5 0.05" (1.27mm) Cortex standard SWD connector.  Only implements SWDIO, SWDCLK and NRST (SWO is not supported on Cortex-M0+).
PCB was designed to be manufactured from the start.  Parts are based on the JLCPCB SMT program.  You can (currently) get the board assembled completely except for the connectors (JLC has no connectors in its SMT program) and a few of the parts that JLC was either out of, or didn't include in the program.  Those parts and their placement were considered so it is possible that they can be hand soldered.  The radio module is the only bottom side component which is easily hand solder-able.  The schematic includes Digikey part numbers for all the parts as well.
The GitHub repo contains all the hardware files to manufacture the board including BOM and CPL files, so you could, in theory, send these off to a PCB house and get the boards made on your own.
I've also put together an STM32CubeMX project file that is compatible with the board if you want to roll your own project.  This includes all the pin definitions that match up to the hardware.  Those pin definitions were carefully selected to match the default LoRaMac-node firmware pins.
Microcontroller pinout
Portable Network Graphics (PNG) - 85.13 kB - 01/03/2020 at 15:37
Preview
Download
pcbBOT.pdf
Fabrication drawing of the bottom side of the PCB
Adobe Portable Document Format - 12.31 kB - 01/03/2020 at 15:29
Preview
Download
pcbTOP.pdf
Fabrication drawing of the top side of the PCB
Adobe Portable Document Format - 33.13 kB - 01/03/2020 at 15:29
Preview
Download
schematic.pdf
Complete schematic
Adobe Portable Document Format - 435.72 kB - 01/03/2020 at 15:29
Preview
Download
loRaWan1262.ioc
STM32CubeMX *.ioc file that matches the Feather board hardware layout. Useful for starting a project based on this board.
ioc - 7.93 kB - 11/19/2019 at 14:27
Download
  • 1 Ă— STM32L073 STM32 Cortex M0+
  • 1 Ă— DRF1262T SX1262 Based LoRa radio
  • 1 Ă— TPS63001 Power Management ICs / Switching Regulators and Controllers
  • 1 Ă— STC3100 Power Management ICs / Power Supply Support
  • 1 Ă— ATECC608A Crypto Co-processor
View all 7 components
  • First Data Visualization
    Andy01/03/2020 at 16:42 0 comments
    I've set up an integration with TTN (The Things Network) and Tago.  I don't know that much about Tago, nor do I endorse it in any way.  It simply was the easiest to setup so I can show what was one of my goals of this project:  sensor data on the cloud.
    Here's a link to the public view of the dashboard I've setup for the project.  Right now, it's basic and just shows some battery data.  I need to update the device (I'm away now) to output the current and charge %, but voltage data is real
  • Project updates
    Andy01/03/2020 at 15:29 0 comments
    Couple of project updates:
    Hackaday has officially closed the Take Flight with Feather contest, they have said that they will notify winners near the end of January, so I'll continue on working away at it.
    I'm still working on getting a useful demo up and running.  I've currently got the LoRaMac-node code taking battery voltages, I'm just working on setting up the TTN based backend and data visualization part.
    I've made another small change to the PCB.  Offically it is at REV C0.  Initially, I thought it would be cool to have the hard secure element on the board as I really haven't seen anyone working on it.  Much later in the design process, I came across the MCCI Catena 4612.  One of my first goes at a LoRaWAN Feather was very similar to this board using the same module.  I had trouble with toaster oven solder reflow yields, so I opted for a discrete solution like what I have now.  On any note, they incorporate an FRAM device which can store provisioning and frame counters without any worry of EEPROM wear out or data retention loss.  Looking at the SOIC8 versions of the ATECC608A crypto chip and really any I2C FRAM device, one can see that the supply pins and the I2C pins are all in the same locations.  The remaining pins are NC for the ATECC608A and are the address pins for the FRAM (similar to any 24LCXX EEPROM).  So by simplying grounding the A0-A2 and WP pins on the PCB footprint, you could fit an FRAM chip or the crypto chip as you see fit.
    I have a couple more almost built boards and I'll probably build a few with FRAM on them and bodge wire the pins to ground.  That way I could maybe put together some code for the hard secure element and maybe some that utilizes the FRAM.
    I also still intend to test out USB on the boards.  USB would be useful mostly for charging and firmware updating but maybe some debugging/diagnostic data could be useful as well.
    I also updated some files here on the project page to reflect some of the project progress.
    I'd love to hear from anyone interested in the project as where to go next!
  • LoRaMac-node running!
    Andy12/26/2019 at 05:31 0 comments
    With the hardware mostly squared away, it's time to finally see if the LoRaMac-node reference implementation from Semtech will run.
    The overall approach will be to add in the LoRaWAN-Feather as a "board" in the reference implementation.  This will require adding my own board support package.  Since my board is based on the STM32L073 and SX1262 it's really just a matter of cobbling together existing pieces of the Semtech code.
    First, I'll fork the repo.  I'll pretty much be using the code from the B-L072Z-LRWAN1 board.  The B-L072Z-LRWAN1 is based on the Murata CMWX1ZZABZ-091.  This is an all in one LoRaWAN solution.  By using this BSP, I won't have to deal with the concepts of shields and Nucleo boards.  But since my boards are running STM32L073's, I'll borrow some parts from the NucleoL073 board support package.  I'll also edit the CMakeLists.txt files to allow for my new platform.  Once I get the new board support package to build and link, I'll move on to adding in the required app examples for my board support package.  So far, all the apps with my board build (they are all copies of the B-L072Z-LRWAN1 apps with the references to extra LEDs removed), but only the classA app has been tested.
    So, if you have the hardware you should be able to clone my fork of the official LoRaMac-node repo and flash it to the board and have it up and running to a gateway of your choice.  If you have a gateway up and running with TTN, it should look a little something like this:
    This shows my custom Raspberry Pi/RAK2245 gateway receiving uplink messages from both of the LoRaWAN-Feathers that are running.
    Up next would be to create a somewhat useful example that maybe has the two LoRaWAN-Feathers uploading the battery data acquired by the on-board fuel gauge.
  • PCB Change
    Andy12/21/2019 at 18:29 0 comments
    Noticed while reading over the STC3100 datasheets that I made a hardware layout mistake.  The first revision boards will function, but accuracy is reduced.  According to AN3395 Section 4, Number 2.  The GND pin of the STC3100 should be directly connected to the CG- pin of the current sense resistor and not through the ground plane.  The PCB layout around the STC3100 is pretty open, so the change was easily made.  The board version has been bumped to B0 and all fab files updated in the GitHub repo.  I also changed R16 and R17 to be DNP by default.
  • Testing the STC3100 on the LoRaWAN Feather Board
    Andy12/15/2019 at 20:09 0 comments
    So I put together a simple project using the *.ioc file that I created for the Feather board, CubeMX and the driver I just put together and the results are good.
    First up is to get rid of the FreeRTOS calls:
    //buf = pvPortMalloc((size_t)(ByteCount + 1));
    buf = malloc((size_t)(ByteCount + 1));
    //vPortFree(buf);
    free(buf);
    and replace them with the standard library calls.
    Also, of course the I2C handle changes too:
    halRet = HAL_I2C_Master_Transmit(&hi2c3, STC3100_SLAVE_ADDRESS_8BIT, buf, ByteCount+1, HAL_MAX_DELAY);
    becomes
    halRet = HAL_I2C_Master_Transmit(&hi2c1, STC3100_SLAVE_ADDRESS_8BIT, buf, ByteCount+1, HAL_MAX_DELAY);
     Here's the relavent portions from main.c
    /* USER CODE BEGIN 2 */
      printf("MCU Init Complete\r\n");
      assert_param( STC3100_Startup() == STC3100_OK );
      printf("Fuel Gauge Init Complete\r\n");
      /* USER CODE END 2 */
     and
    while (1)
        /* USER CODE END WHILE */
        /* USER CODE BEGIN 3 */
    	  HAL_GPIO_TogglePin(USER_LED_GPIO_Port, USER_LED_Pin);
    	  assert_param(ReadBatteryData() == STC3100_OK);
    	  printf("Battery Data (%d):\r\n", s16_BattCounter);
    	  printf("\tVoltage(mV)\t%d\r\n", s16_BattVoltage);
    	  printf("\tCurrent(mA)\t%d\r\n", s16_BattCurrent);
    	  printf("\tTemp(0.1degC)\t%d\r\n", s16_BattTemperature);
    	  printf("\tCapacity(mAh)\t%d\r\n", s16_BattChargeCount);
    	  HAL_Delay(1000);
    Again, pretty simple.  I wrap the STC3100 library calls in assert statements for debugging purposes.  That way if there is an error, it ends up in the assert failed handler and I have some basic debugging clues left behind.
    Anyway the result runs (capture from PuTTY):
    Battery Data (29691):
            Voltage(mV)     4186
            Current(mA)     -1
            Temp(0.1degC)   213
            Capacity(mAh)   401
    Battery Data (29693):
            Voltage(mV)     4186
            Current(mA)     -1
            Temp(0.1degC)   213
            Capacity(mAh)   401
    Battery Data (29695):
            Voltage(mV)     4186
            Current(mA)     -1
            Temp(0.1degC)   213
            Capacity(mAh)   401
    Battery Data (29697):
            Voltage(mV)     4186
            Current(mA)     -1
            Temp(0.1degC)   213
            Capacity(mAh)   401
    and the I2C waveforms look good on the scope:
    So I'm happy about the hardware and software around the fuel gauge IC.  I don't plan at the moment to look at the crypto chip.  Instead, I'll switch now testing the radio or getting a whole LoRaWAN project up and going on it.
    For reference, here's my debug setup:
    I've got the Feather board with the Tek probes grabbing on to the I2C pins of the crypto chip (the only place I can easily grab the I2C bus), the ST-LINKV3, a battery and the scope probes off to the side.  The yellow and green wires are the LPUART connected back to the VCP pins that give me a Virtual COM Port from the ST-LINKV3.  The black USB cable was charging the battery
  • More STC3100
    Andy12/15/2019 at 19:48 0 comments
    Now onto the STC3100_Read method:
    int STC3100_Read(unsigned char ByteCount, unsigned char RegisterAddr , unsigned char * RxBuffer)
    	HAL_StatusTypeDef halRet = HAL_OK;
    	if(!RxBuffer)
    		return( halRet = HAL_ERROR);
    	halRet = HAL_I2C_Master_Transmit(&hi2c3, STC3100_SLAVE_ADDRESS_8BIT, &RegisterAddr, 1, HAL_MAX_DELAY);
    	if(halRet != HAL_OK)
    		return halRet;
    	halRet = HAL_I2C_Master_Receive(&hi2c3, STC3100_SLAVE_ADDRESS_8BIT, RxBuffer, ByteCount, HAL_MAX_DELAY);
    		return halRet;
    	return halRet;
    Pretty simple and straightforward stuff.
    The code works on the Charger 2 Click and I get back readings that seem to look just fine.  Now onto adapting it run on the LoRaWAN Feather board.
  • More Testing...
    Andy12/15/2019 at 16:32 0 comments
    Time now to take a look at the STC3100 fuel gauge IC.  As a starting point, I'll be using this library on GitHub.  I'm not sure if it is an official ST repository/account, but the driver looks useable.  It just needs an I2C implementation added to it.  I've pulled the 4 required files out and put them into my own repository.  To initially test the code, I'm using the Charger 2 Click from Mikroe in my Clicker 2.  The Clicker 2 uses an STM32F4 but that will allow me to reuse the code on the STM32L0 on the LoRaWAN Feather thanks to CubeMX.  The STM32F4 project is based on FreeRTOS and CubeMX.  Of course, FreeRTOS isn't required as we'll see on the code that runs on the Feather.  Here are the I2C methods I wrote to talk to the chip:
    First, STC3100_Write
    int STC3100_Write(unsigned char ByteCount, unsigned char RegisterAddr , unsigned char * TxBuffer)
    	uint8_t *buf;
    	if(ByteCount == 0)
    		return(halRet = HAL_ERROR);
    	if(!buf)
    	buf[0] = RegisterAddr;
    	for(int i = 0; i < ByteCount; i++)
    		buf[i+1] = TxBuffer[i];
    		return halRet;
    	vPortFree(buf);
    	return halRet;
  • Forgot to show you the bottom
    Andy12/04/2019 at 23:08 0 comments
    Just realized I didn't snap a photo of the underside with the radio module.  So here is yet another crappy photo
  • Update!
    Andy12/04/2019 at 23:02 0 comments
    Update on the project after the holiday!  I got in the semi-assembled boards from JLCPCB.  I'm very happy with the quality and speed of the assembly process.  The boards look great:
    Sorry for my crappy photography skills.  JLC doesn't have any connectors in their SMT assembly library which is strange, so they aren't assembled.  The three user buttons were supposed to be assembled, but that was an error on my part.  I did not select a part on the BOM selection step of the process.  Oh well, Digikey to the rescue.  The rest of the parts were either not in stock or not available for assembly.  Time to get out my iron!
    I decided to start with two so that I can run the LoRaWAN stack's ping pong application as a test as well as get them connected to my Raspbery Pi based LoRaWAN gateway for testing.  However, some initial testing is in order first!
    To date, I've done a basic power on test using the 3.3V from a bench supply, the battery and 5V via USB and all function as designed.  This tells me that my DC-DC is working, as is the rest of the power system.  Battery charging also works.
    I loaded up a simple blinky application and it runs, proving my SWD and crystal circuits are working.  Only snafu there is that the LED is green instead of red!  Probably an error on my end again, but a minor one.
    Only issue I've noticed so far is that I populated R16 and R17.  With the STM32 USB FS Phy, pullups on the D+/D- line aren't required, but I wanted to have the pads there just in case.  I'll have to desolder those when it comes time to test the USB.
    My next step is to write some basic code to test the battery fuel gauge and at least make sure I can communicate with the crypto coprocessor.
    So far, off to a good start!
  • PCBs
    Andy11/19/2019 at 14:15 0 comments
    Looks like the missing parts were errors on my end (go figure).  The common mode filter for USB was out of stock and I didn't select a suitable replacement (which was available).  The switches were in the CPL file, but not the BOM so they won't be placed.  I've ordered the balance of parts from Digikey and should be able to finish off the boards by hand.  As of this morning the PCBs are almost done with production.  I've updated the schematic with part numbers from Digikey for all the parts.
View all 12 project logs
Rafael wrote 02/15/2020 at 05:47 point
This is a really nice project, well done. Is your latest rev design working well? If you'd like to learn how to create visualizations with Grafana, please let me know, I just recently started testing the MQTT integration from The Things Network with Telegraf+InfluxDB+Grafana.
Andy wrote 12/04/2019 at 23:15 point
Thanks!  I'm just hoping it works and isn't an undersized drink coaster like the rest of my designs!
Kirschner Christoph wrote 12/03/2019 at 07:03 point
cool project!! whats the partname of the lipo connector?
Andy wrote 12/04/2019 at 23:14 point
It's a standard JST battery connector.  https://www.digikey.com/product-detail/en/jst-sales-america-inc/S2B-PH-SM4-TB-LF-SN/455-1749-1-ND/926846
It won't be blue in final assembly, although that would be really cool, it was just the only 3d model I can find.
davedarko wrote 12/02/2019 at 21:42 point
Nifty and way more elaborate than mine :)
