Maduino Zero NFC
New Maduino Zero Series board with NFC
Maduino Zero NFC is an Arduino compatible small development board with NFC (Near-Field Communication).
This board will be the bridge that helps you wirelessly interact with your environment, drive motors, unlock strikes, control relays, read from a temperature sensor and all thanks to built-in NFC connectivity, right out of the box. Same other Maduino Zero boards, this board is based on ATSAMD21G18(which actually makes it available to work with MicroPython, if you re-program the bootloader)
These days I am writing the user guide for this detaied usage for this module, should release it within this month
Features:
1. Arduino compatible(with Arduino bootloader)
2. ATSAMD21G18, 32-Bit ARM Cortex M0+
3. Size: 40*55mm
4.Support Micro SD Card
5. 18* GPIO
6. 13.56M wireless NFC
By the way, i am also planning to make it MicroPython compatible....:)
Maduino Zero NFC v1.0.brd
Maduino Zero NFC Eagle brd File
brd - 504.30 kB - 11/20/2019 at 06:04
Download
Maduino Zero NFC v1.0.sch
Maduino Zero NFC Eagle Schematic
sch - 458.68 kB - 11/20/2019 at 06:03
See BOM
Download
