Experiment #1
A project log for Scarab - Hexapod Robot
3D printed hexapod robot controlled by ROS
vladimirVladimir 11/20/2019 at 15:500 Comments
Here is the first experiment with a robot leg and solving inverse kinematic problem algorithm. Software was written in C++ running ROS Kinetic. A marker was attached to the end of the leg in order to check correctness of the algorithm. Also reference trajectory is a circle.
This is a visualized scheme of software.
Every node has a special function:
See my github page for the full source code https://github.com/yoggi56/hexapod
