3.2 with a final Face Recognition fix
A project log for $7 ESP32 CAM example expanded
A proper implementation of a ESP32 CAM webserver; based on the Espressif example, but extended for real-world use
owenOwen 05/17/2021 at 11:340 Comments
I've done a V3.2 release
This contains a small but significant bugfix that caused streams to crash if a still image capture occurred while face recognition is enabled. It is fixed by disabling face recognition on image captures while the stream is running.
