V3.1 because... ESP
A project log for $7 ESP32 CAM example expanded
A proper implementation of a ESP32 CAM webserver; based on the Espressif example, but extended for real-world use
owenOwen 05/09/2021 at 16:230 Comments
This is a new minor release to incorporate fixes for the ESP 1.0.6 Arduino IDE version (which broke frame size selection).
I also added some more detail about the number of served streams and images to the dump page, and improved the serial dump/debug behaviour so that you can request an info dump anytime, and it now works in AP mode too.
