V4 beta, dropped cheesy face recognition, added OTA
A project log for $7 ESP32 CAM example expanded
A proper implementation of a ESP32 CAM webserver; based on the Espressif example, but extended for real-world use
owenOwen 05/31/2021 at 14:470 Comments
On a new branch in the repo:
https://github.com/easytarget/esp32-cam-webserver/tree/NoFace
Note that you need to select a different board than the usual 'AI-THINKER' one in the IDE for this since OTA uses a dfferent memory partitioning scheme. See the updated README on the branch for more.
