The firmware file attached to this post has a Windows "BAT" file for programming with a USB Tiny Device & avrdude.    If you're not using Windows here are the commands that are in the file for you to run on your respective device:
avrdude -v -p attiny13 -P usb -c usbtiny -e -Ulock:w:0x3F:m -Uhfuse:w:0b11111101:m -Ulfuse:w:0x7A:m
avrdude -v -p attiny13 -P usb -c usbtiny -Uflash:w:Wireshark_Firmware.hex:i
