Thoughts on timekeeping
A project log for RAD2 (Research Activity Detector version 2)
This motion logging Feather-compatible shield contains a PIR motion sensor, real time clock (RTC), microSD card slot, and 3 signal LEDs
lex-kravitzLex Kravitz 11/23/2019 at 14:040 Comments
Some excellent thoughts on timekeeping by Terry Moore!
Timekeeping is a thorny topic for scientific investigations, because one day is not exactly 86,400 seconds long. Obviously, the difference between two instants, measured in seconds, is independent of calendar system, but converting the time of each instant into ISO date and time is not independent of the calendar. Worse is that catena-message-port1-format-22.md 10/19/2019 computing systems (e.g. POSIX-based systems) focus more on easy, deterministic conversion, and so assume that there are exactly 86400 seconds/day. In UTC time, the solar calendar date is paramount; leap-seconds are inserted or deleted as needed to keep UTC mean solar noon aligned with astronomical mean solar noon.
In effect, the computer observes a sequence of seconds. We need to correlate them to calendar time, and we need to interpret know the interval between instances. Let's call the sequence of seconds interval time, as opposed to calendar time. Let's also define an important property of sequences of seconds -- "interval-preserving" sequences are those in which, if T1 and T2 are interval second numbers, (T2 - T1) is equal to the number of ITU seconds between the times T1 and T2. Since the RTC runs in calendar time, but we do all our work with interval time, we must consider this.
There are (at least) three ways of relating interval time to calendar time.
  1. 1. Keep interval time interval-preserving, and convert to calendar time as if days were exactly 86,400 seconds long. (GPS is such a time scale.) Differences between instants (in seconds) are in ITU seconds.
  2.  Keep interval time interval-preserving, but convert to calendar time accounting for leap seconds (most days are 86,400 seconds long, but some days are 86,399 seconds long, others are 86,401 seconds long). (UTC is such a time scale.) Differences between instants (in seconds) are in ITU seconds.
  3.  Make interval time not interval-preserving by considering leap seconds. A day with 86,401 ITU seconds will have two seconds numbered 86,399; a day with 86,399 ITU seconds will not have a second numbered 86,399. Convert to date/time as if days were exactly 86,400 seconds long. The difference between two instants (in interval time) is not guaranteed to be accurate in ITU seconds.
Steve Allen's website has a number of good discussions, including:
  1. Issues involved in computer time stamps and leap seconds
  2. Two kinds of Time, Two kinds of Time Scales
The onboard real-time clock counts in "calendar" time, and will be set by people (again in "calendar" time) from watches etc. that run from UTC or a derivative. We will assume that the user can input the time in UTC and that the battery-backed RTC is recording time in UTC. Therefore, we use a timescale that simply states that days have 86,400 seconds. In this application, we think that this will be good enough. If we ever start to use LoRaWAN ("GPS") time, we assume that the network will be able to send us the information needed to convert to calendar time as needed. This may add a little complication but it's future complication and we'll deal with all this if the need arises.
