Feather Wing PMOD Adapter
Simple feather wing to allow pmod modules to be used with feather boards.
0 followers
Simple feather wing to allow pmod modules to be used with feather boards. The connectors are compliant with the uart, spi and i2c pmod standards. The two vertical connectors are spaced to allow a dual pmod to be inserted.
See https://github.com/TomKeddie/prj-pmod-feather
  • v1.0 assembled
    TomKeddie12/10/2019 at 18:55 0 comments
    I've assembled v1.0 and it looks great.  I ended up using a single connector for both pmods to ensure placement accuracy.  This would not be needed for mechanical placement.
View project log
