AD5245 Digital Potentiometer Breakout
A small breakout board for testing the AD5245 I2C Digital Potentiometer
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The AD5245 Digital Potentiometer breakout board is a simple implementation of the Analog Devices' I2C, 10K-ohm chip. The potentiometer sports 256 resistance steps and can work with a power source from 2.7v to 5.5v. The pins act similarly to a passive resistive potentiometer, but require that voltages placed on any of the three pins not exceed the power supply voltage or drop below ground potential. A CircuitPython library is included in the code folder of the GitHub repository.
