1. Take 2 transparencies, turn them with the top edge inside, so you only have the bottom edge to hold and eventually staple. Hold the top corner tight to turn pages as tight as possible, to make a tiny hole at the top for the LED String to hook on. Staple the bottom corner. Cut of the extra at the bottom to make the cone flat. https://www.amazon.com/dp/B078QYKNKG/ref=cm_sw_r_tw_dp_U_x_Yt02DbD1JD96W
  2. Use spray adhesive to spray the inside. https://www.amazon.com/dp/B00178QR1K/ref=cm_sw_r_tw_dp_U_x_4u02DbVGVBNVC
  3. Prepare a ratio of sequence to throw against the adhesive. Repeat till covered. Shake the tree, get the extra and use inside. Let dry. https://www.amazon.com/dp/B01N6NPOYL/ref=cm_sw_r_tw_dp_U_x_mv02Db4B90V5R
  4. Trace the circle of your tree on cardboard, add half an inch diameter and cut out. You should get a circle a little larger than your tree bottom. Go around the circle and make cuts around the circle so you can then fold these folds to make a base for the tree. You can also use the templates attached for different sizes. Fold the ends and sit it ready. See Template.
  5. Use double sided tape to glue the base of the LED to the bottom of the cardboard in the center so that later when tree stands it's stable. Extend the wire through the side up. Thread the LED to the top and bend on the top. Turn the string inside to wrap. https://www.amazon.com/dp/B07H2ZX98D/ref=cm_sw_r_tw_dp_U_x_Ev02DbYESXYBM
  6. Spray the sides of the base and push it inside. Test it out. Tada!
